88 possible tranny prob or something else?
Old Feb 24, 2007 | 03:54 PM
Jims1988C4's Avatar
Jims1988C4
Default 88 possible tranny prob or something else?
Besides all the little problems Iv been having lately due to not driving her for about a month,I took her out today and ( I have an automatic) she goes into 1st no problem but when she goes into 2nd the cars RPMs bolt to around 3500 and im only going around 20mph,I can feel it slipping,I put her in low 1and 2 and the trans holds fine,no noises,clanking shes smooth but just doesn't hold 2nd,the last time i drove her she was perfect. I checked the trans fluid and its as sweet as new,I had a complete trans flush about 2500k ago.Anybody have this problem and what can i do next ?? Thanks
Old Feb 24, 2007 | 03:57 PM
Pete K's Avatar
Pete K
The band applies for 2nd gear. Sounds like overhaul time.
Old Feb 24, 2007 | 04:18 PM
Jims1988C4's Avatar
Jims1988C4
OK, IM looking at a sixpack now,tell me how much that will cost me.and should I buy more beer ??????
Old Feb 24, 2007 | 04:30 PM
qws's Avatar
qws
Overhauls aren't that bad. I got robbed on mine cost me like $2400, but I also changed the TQ, and installed the shift kit. I'm sure PeteK remembers me doing it last year... I was going nuts!....
Old Feb 24, 2007 | 04:33 PM
Pete K's Avatar
Pete K
Tough question to answer. Local labor rates will determine alot of the price variables. Parts used/upgrades vary greatly as well.
I stronly recommend rebuilding the unit you have, rather than swapping it out.
Old Feb 24, 2007 | 04:40 PM
Pete K's Avatar
Pete K
I just completed a build for another forum member in New Jersey. He dropped off the trans and I made major upgrades to it. Along with the overhaul, we used thse h/d parts:
Alto red kit with kolene steels and h/d 3-4 clutch kit
Teflon pump and tail bushings
kevlar band
beast reaction shell
4th gear billet servo
bigger pump boost valves
new sprag (29 element) and lo-roler clutch
Transgo shift kit(supplied by customer)
Input drum reinforcing sleeve and cryo'd forward piston
etc
His total was less than $1,250 including the cost of the shift kit.
Torque converter was not included.
This represents the low end(price wise) of a heavy duty build.
Stock builds are much cheaper.
Old Feb 24, 2007 | 04:52 PM
Jims1988C4's Avatar
Jims1988C4
Thanks pete,its just a nice weather driver,im not looking for any mods or upgrades,I just want a quality job done so i can drive her and not worry about it happening again...
Old Feb 24, 2007 | 05:01 PM
Pete K's Avatar
Pete K
From the sounds of it, you need the following (in my opinion):
Remanufactured torque converter
rebuild
upgraded 3-4 clutch kit.
If you can remove and replace the trans yourself, you can save a few hundred bucks
Old Feb 24, 2007 | 06:17 PM
Kool88vette's Avatar
Kool88vette
If your tranny needs a rebuild I would recommend a Transgo shift kit and a maybe a torque convertor. It's a lot cheaper when the tranny is out.
To 88 possible tranny prob or something else?
