Switching too vented Opti-Spark
Old Feb 25, 2007 | 12:11 AM
Strike3's Avatar
Strike3
Default Switching too vented Opti-Spark
Ok! I've searched this forum and read some articles. I have a new vented distributor for a 1995 vett. I have the GM double vent hose which hooks to the distributor, but..............
What I don't know is, do I have to change from a timing gear cover with a small distributor hole (92 thru 94 version) to a large hole 95 version???? I'm guessing Yes, but I haven't seen it specifically addressed in anything I've read so far. Can the small hole cover be modified by a machine shop??
Old Feb 25, 2007 | 01:11 AM
STL94LT1's Avatar
STL94LT1
Yes, you'll need a 95 timing cover, a longer dowel pin in your camshaft or a new camshaft, and a 95/95 opti wire harness.
Old Feb 25, 2007 | 07:18 AM
LannyL81's Avatar
LannyL81
Additionally you will need to have a vacuum source for the OptiSpark vacuum hose to go onto....stock comes off the intake, just below the throttle body.
And you will have to put a hose connector into your fresh air intake after the air filter.
To Switching too vented Opti-Spark
