How to set timing? Do I need to pull the plug?
Old Oct 8, 2001 | 04:52 PM
Dave's_88's Avatar
Dave's_88
Default How to set timing? Do I need to pull the plug?
I'm using a timing gun that allows you to electronically set the timing in the computer (advance/retard). Do I still need to pull the distributor plug or does this gun take care of that?
Thanks,
Dave
Old Oct 8, 2001 | 04:57 PM
scorp508's Avatar
scorp508
Default Re: How to set timing? Do I need to pull the plug? (Dave's_88)
Yep.... yank the brown wire, set the timing, plug brown wire back in.
Old Oct 8, 2001 | 05:51 PM
Dave's_88's Avatar
Dave's_88
Default Re: How to set timing? Do I need to pull the plug? (scorp508)
Which wire is it? I know, brown wire...but. Is it the tach wire on the rotor cap (actually two wires, tan & brown connected with a brown clasp)? Is it an electrical wire or some sort of vaccum hose?
Thanks,
Dave
Old Oct 8, 2001 | 07:10 PM
BobMachus's Avatar
BobMachus
It is a tan w/ stripe (or brown w stripe) wire with a quik-connect between the brake booster and the Distributor. Unplug that, shoot your timing, plug it back in.
Bob
To How to set timing? Do I need to pull the plug?
