C4 leaf springs
Use http://www.suspension.com to find the part numbers for your sway bar bushings (24mm or 25mm) and whatever shock bushings they have, neither are in the $180 kit. I wouldn't order from them though, use Summit.com.
That and a little marine grade grease, and some elbow grease and your problem is solved.
Plan on needing new upper and lower balljoints (~$80 each) from www.rockauto.com, and new tie-rod ends for the steering, and new shocks, and bearings. Use Moog or a good USA brand for ball joints/tierods, the offshore stuff is garbage, won't last, and sometimes won't even fit.
I had to replaced all this on my '85 and only have 85,000 miles on it. After you do all that, get a grease gun and grease the zerk fittings on all the balljoints and tie rod ends once per year.
Except I would buy an $80 hydraulic press from Harbor Freight to do the bushings and press in/out the lower ball joint. I decided the vice/ball joint c-press method was a waste of my time and bought this:
In less than 30 minutes I had the old stuff pressed out and the new stuff pressed in, like this:
Coach wants to know the extent of the OP's experience, offers some suggestions for describing symptoms, and asked for more information.
Where's the problem...?
He said it a lot nicer than some of us would have.....
Larry
code5coupe
