C4 leaf springs
Old Feb 25, 2007 | 11:53 PM
jimmyvet1's Avatar
jimmyvet1
7th Gear
Default C4 leaf springs
My 84 front spring makes a snapping and creaking sound that I can feel
in the center of the spring. Has anyone had that happen and will I need to replace the spring?
Can anyone tell me if any or all C4 front leaf springs will fit an 84? I have heard that the 90 springs were the best designed for the C4. Does anybody have info on that or should I check out coilover shocks?
Old Feb 26, 2007 | 12:26 AM
bogus's Avatar
bogus
I don't know how anyone can say the 1990 spring is the "best design." what constitutes best design?
you have a couple of options, one is used, www.vette2vette.com, another is www.vettebrakes.com, they sell a nice line of aftermarket composite springs.
I donno about coil overs on an early C4.
Old Feb 26, 2007 | 01:44 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by jimmyvet1
My 84 front spring makes a snapping and creaking sound that I can feel in the center of the spring.
Can you be more specific as to how you feel the sound coming from the center? It is possible to view this area by removing the lower covers and illuminating with a good light source. Look for any signs of white powder (fiberglas grindings) or jagged shards of fiberglas splinters or cracks. With the front end jacked off the ground these abnormalities should be easy to recognize.
Old Feb 26, 2007 | 01:50 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Loud creaking noises are more likely from the front control arm bushings, or the rubber spring ends against the lower control arms, or the sides of the spring pivots rubbing on the spring retainer brackets.
Push down on the front fender and listen closer. I'd think a busted spring would make more of a tearing noise if any, and the front of the car would already be way lower than stock.
Old Feb 26, 2007 | 02:16 AM
vader86's Avatar
vader86
84-87 springs are the same in the front. You cannot use springs from a later year than 87 in front unless you want to redo almost the entire front suspension. 84's handle better very good, so changing to a later spring is not going to make it any better. There were other design changes in the later years to improve handling without the ride quality of the 84.
Rears are the same, so you can use those from later years.
If the spring is broken/delaminated, it will require replacement.
But most noises do come from worn bushings, any could be bad on a car that old, and all probably need to be replaced.
Old Feb 26, 2007 | 12:45 PM
smearig's Avatar
smearig
It's probably bushings or ball joints. I just replaced both in my '84 and the bushings literally crumbled to pieces when I pressed them out of the control arms. The ball joints were flopping around loose and the protective boots were not holding grease. I'm guessing this is more likely the case for you than a broken spring. FWIW, I am pretty sure my spring is stock with 242k miles on it and it looked just fine when I took it out.
Old Feb 26, 2007 | 06:36 PM
jimmyvet1's Avatar
jimmyvet1
7th Gear
To be more specific I put my hand on the spring at the car center and that is where you can feel the spring pop the most and is where the sound is the loudest. Other than that listening from either side you could not tell where the sound was iminating from (equal on both sides).
When pushing down hard you get a creaking sound and less of a pop but the sound still seemes to be coming from the middle of the spring. I cannot see any cracks or damage anywhere on the spring. I had the guys at NAPA frame shop look at it and that is what they said was the problem but I don't want to just jump out there and spend money if it is not the problem. That is why I got under the car and checked out what they were saying.
Old Feb 26, 2007 | 06:50 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
242k ...
Mine were like that too, a poly upgrade is a good idea when workin on it.
Old Feb 26, 2007 | 07:42 PM
jimmyvet1's Avatar
jimmyvet1
7th Gear
It is obvious that the bushings need to be replaced, I don't know about the ball joints. They don't appear to be bad. I need to replace a tie rod end that is worn. This car was not maintained very well by the previous owner and I am playing catch-up now. Thanks for helping me confirm my symptoms.
Old Feb 26, 2007 | 08:08 PM
JrRifleCoach
Oh Boy! SO how much mechanical experience do you have?
Word like "obvious, appear and I don't know" are sketchy.
Maybe some profile info would be helpful to gain further info.
Old Feb 26, 2007 | 09:15 PM
smearig's Avatar
smearig
If you can easily move the ball joint around by hand you might consider replacing it. You should feel how tight a new Moog ball joint is. I was thinking mine "weren't that bad" until I felt a new one. How many miles do you have? There are also bushings where the spring mounts to the cross member, those could be shot too.
Old Feb 26, 2007 | 09:27 PM
CentralCoaster
Original lower ball joints have a wear indicator. As soon as the edge of that surface the grease fitting attaches to, drops beyond the edge or the metal cap, it needs to be replaced.
GOOD
BAD
Old Feb 26, 2007 | 09:31 PM
CentralCoaster
How'd you do this? With the car on a lift and reaching into the holes in the bottom of the spring channel? Anyhow, and creaking from dry or rotted bushings would be trasmitted through the spring, so this test doesn't really say anything.
You're going to need a bushing install anyways, my guess is on disassembly you'll find the problem before you even get to the spring. I would not buy a spring "just in case". Wait till you get it torn apart. There are so many things that can cause this. My car did the same, very loudly. And it wasn't the spring. But I covered those items in my first post.
Get the car on blocks or jackstands and remove the two spring retainers. See how shiny they are on the inner sides. These squeak really loud from the spring pivoting, and need to be lubed.
Old Feb 27, 2007 | 12:36 AM
jimmyvet1's Avatar
jimmyvet1
7th Gear
I would like to thank all the people that have given me very good advice on my question and will look into all the sugestions I have received. may I say that Coach, you should not be so condisending as you may not know aas much as you think you do. I have only asked about this because my experience on this model of corvette is limited. You would be better served to try and help than to act as though you were "all that". I haven't heard any sugestions as to what the problem may be or other alternatives to consider. As to my experience Iwas working on cars before you were born.
I again want to thank all that have given advice to my question. Yo have been a great help.
Old Feb 27, 2007 | 01:04 AM
Casethecorvetteman's Avatar
Casethecorvetteman
If you were working on cars before he was born you should know all the answers already, its all pretty straight forward. I think you have simply misunderstood what JrRifleCoach was getting at. If you fill out your profile, it helps us to help you.
Old Feb 27, 2007 | 01:10 AM
CentralCoaster
JrRifleCoach, why doncha leave the narcissistic and condescending comments up to me, ok!?
Old Feb 27, 2007 | 01:14 AM
jimmyvet1's Avatar
jimmyvet1
7th Gear
You are probably right. I will rebuild the front suspension eventually and take care of my problems in doing so. I just could not figure out where this noise is coming from. The car has 168k on it and it appeared that the previous owner had never greased it so I'm sure there are many things in need of replacement. I just like to know what is causing a problem before I just start changing stuff. I am not like the dealer mechanics. I can't afford to be.
To C4 leaf springs
Old Feb 27, 2007 | 01:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Hang around and youll get a feel for everyone here, you took JR wrong. He is very good with suspension on these C4s...Maybe he'll post up some of his handywork..
Old Feb 27, 2007 | 01:26 AM
CentralCoaster
You'll never be 100% sure before tearing into it. But trust me on this. I don't know about the others on here, but this below comes from my first hand experience. It made for VERY loud creaking noises and was a cheap/free fix that I put off for too long.
Originally Posted by CentralCoaster
Loud creaking noises are more likely from the front control arm bushings (specifically lowers), or the rubber spring ends against the lower control arms, or the sides of the spring pivots rubbing on the spring retainer brackets.
Old Feb 27, 2007 | 01:56 AM
JrRifleCoach
Mmmm I think theres room for the both of us here.
Sometimes I gotta just smile at some of these NOOBs. We post help and they either ignore the posts or challenge the writers. No profile info to assist with their problems, heck I had to look up jimmies posts, all 8 of them, to find out that he has a "Red 84".
In the mean time jimmie boy has made a point that needs clairification;
Tell ya what jimmie, continue to ask questions and attempt to troubleshoot with the others here. Since I'm not that knowledgeable in your book, I'll place you on my IGNORE list and life will once again be sunshine and cloudless skies for the both of us.
BTW condisending is spelled condescending. Buy a spell checker Einstein.
