Low Budget Front Skinnies
Rssshen Vette
__________________
Rssshen Vette
85 Coupe -383ci, 4340 forged scat crank, 6" Hbeam rods, .030 forged flat top pistons, Dart Pro 1 alum heads, Comp Cam X4 270HR, Roller Lifters, 1.6/1.5RR, harden push rods, hi flo base intake, 24lb accel injectors, adjustable fuel regulator, stock plenum ported to match BBK 58mm TB, Stock TPI runners, MSD6AL, chip by Alvin, TPIS headers w/ 3" Ypipe, flo master40's, 3.73 gears, BFG Drag Radials
6/30/2006
60' 1.78
1/8mi. 8.16@ 84.77
89 for wheels each (its a star 5 spoke) made by summit. 15" fit perfect on my 85 vette.
and 79 for tires 155/R/15" made by BFG radials and its Dot so u can even drive all the way to track, i drove mine with these skinnies to 2.5 hrs drove to track without any problem.
That's what we ran on drag cars way back when. I think by the old sizing standards they were 5.60/15. I also used a VW gas tank on my oval track car. They were small, bottom feed and they worked very well. Fuel cells weren't mandatory back then but I did have it very well protected.
i agree u can buy brand new tires on ebay too for 40 bucks eac or buy at pep boys. i wish i would have known that,
but the tires i bought from summit is bfgoodrich radials and its DOT with 400 AA traction rating, u can even drive around town and still be able to drive to track without replacing at track. Heck iam driving with same wheels around town and already logged 500 miles on them.
Less rolling resistance, but if they don't weigh much less, you won't get as much benefit.
On my '93, the stock front wheel with a 255 tire weighs in at 46 lbs.
I put a 15 x 3.5 Weld Pro Star with a 165/85R15 tire and it came in at 24 lbs.
But I just bought the CCW Drag Oack and the front wheel tire combo weighs 38 lbs.
