300 h.p.
Old Feb 27, 2007 | 02:46 AM
Puna's Avatar
Puna
Default 300 h.p.
What would be required to squeeze a measly 300 horsepower of an 89 L-98. Plans include exhaust and hotter ignition. Air foil, tornado would I have to do a cam change and get into the motor, it's just a
street toy or are there easier ways, maybe I cpuld just lose 40-50 pounds and lighten things up.
Thanks Vetters
Old Feb 27, 2007 | 08:19 AM
Mekanic's Avatar
Mekanic
you mean a +300 bump?
Yeah, you're gonna have to get into the engine, and get some forced induction, and a crapton of money.
If you just want to get to 300WHP then I'd say some intake work should be your first stop. I'm not that familiar with L-98s but I've heard a ton of talk that thats your weak link. Hopefully some of the L-98 guys will jump in here for better info.
Old Feb 27, 2007 | 08:21 AM
ODIVETTE's Avatar
ODIVETTE
the easiest way (maybe not the cheapest) is a supercharger. No question. But if that is not your style, you are going to have to open up the engine. All the bolt-ons out there aren't going to free up 60 to 70hp.
Old Feb 27, 2007 | 08:41 AM
mrc24x's Avatar
mrc24x
If you are looking for a noticeable increase then start with the exhaust. Headers and a free flowing full exhaust will put you around 250 rwhp (peak) but it is a 40-50 Hp increase @4500-5000 rpm vs stock. If that isn't enough of an improvement then...1.6+ RR's, heads,cam +super Ram should put you in the 300 rwhp ballpark.
Old Feb 27, 2007 | 09:04 AM
madman91's Avatar
madman91
are we talkin at the wheels or the crank? not to hijack but i have a 91 and im also interested in the answer but my starting point is 250hp
Old Feb 27, 2007 | 09:25 AM
vader86's Avatar
vader86
Thanks Vetters
300chp would be fairly easy. 300 at the wheels requires some work.
No airfoil and no tornado, no need for expensive ignition parts because stock HEI will be just fine with the TPI engine.
there are more details on my website, but longtube headers, bigger base, ported plenum, AS&M Runners should get you to your 300chp level. Further would require a cam change.
Old Feb 27, 2007 | 02:09 PM
madman91's Avatar
madman91
what would a full exhaust system( catless front y pipe, high flow cat, and muff elim.) with stock manifolds gain?
Old Feb 27, 2007 | 03:15 PM
kopbet89c4's Avatar
kopbet89c4
I dynoed at 275 hp, 305 tq to the wheels with 12 degrees of timing, a Miniram and a free flowing exhaust. About 330 hp, 365 tq at the crank. This explains my low 13 second passes with 105 mph trap speeds. I'd hope to do better with my 2.5" true dual exhaust.
Old Feb 27, 2007 | 06:31 PM
Razor89's Avatar
Razor89
I made it with a lot of work. check my sig.
To 300 h.p.
