ok, My AC blows Cold, and works, but, it stays on defrost only, I push the buttons and wont come out of any vents, only comes out the defroster, and down by the legs. what could be the problem?
It's most likly this vacuum valve under the fuel rail.
so it that some kind of sensor, and was your car doing the same thing?
Actually my Cruise control didn't work. I really don't use the AC. The valve runs both. The heat kills these valves. The valve is similar to a pvc valve. Cost about $6
If you want to know anything about AC, do a seach on forum member SUNCR he is the guru of AC problems... You will see your problem come up quite often.... Check out this thread too... http://forums.corvetteforum.com/show....php?t=1475173
so then I should take a look at my 90 degree wire, is it easy to replace? and thanks for the info
Its not a wire. It actually a vacuum hose. Personnally I would just put a new valve on. If it's not bad, its probably about ready to be. Let face it, it cost $6, I spend $6 in one pull at the slot machines.
Just remove the rail cover, it takes about 5 minutes to put in.
If you still have problems, it's one less cheap part that people will suggest....
srry for askin the same question alot, but can I buy this part at auto zone, or oriellys, and what is it called, or what do I ask for to get the part? thnks
Anytime your looking for a part and you know the part # (See my picture above) you can see if it fits your car by going to ACDELCO.com. You can also see what part Delco make for your car by going to the same site...
