dash backlighting problem
Old Mar 2, 2007 | 06:11 PM
814speed's Avatar
814speed
Cruising
Default dash backlighting problem
The backlighting isnt working in my dashboard. This includes the a/c, radio, headlight switch, etc. The instrument cluster backlighting is working great and adjusts fine. My vette is a 91 automatic. I have checked all my fuses. Any ideas would be much appreciated. Thanks.
Old Mar 2, 2007 | 06:19 PM
Ttime's Avatar
Ttime
Try checking and testing the dimmer switch.
Old Mar 2, 2007 | 07:03 PM
814speed's Avatar
814speed
Cruising
The dimmer works great with the cluster so I havent suspected it. Should I?
Old Mar 3, 2007 | 02:29 PM
814speed's Avatar
814speed
Cruising
I checked the dimmer switch and it works perfectly. It seems that the purple wire with a white stripe is the problem. As it reads no connection to power or ground. Are there any other components involved in the dimming operation that could fail?
Old Mar 4, 2007 | 03:19 PM
814speed's Avatar
814speed
Cruising
A little additional information. It seems that the radio at one time has been stolen from my car. When I removed the aftermarket one installed there was no factory radio wiring including the antenna. Could this be the cause of my issue? I really need a diagram.
To dash backlighting problem
