C4 Brake mounting question
I'm installing the HD brakes on the front end of a 1996 vette.
I can't figure out how the caliper mounts to the mounting bracket. Do you put the new pads in and then put caliper in the bracket then put on the rotor and bolt up? When does the pin go in?
thanks
Install the rotor and bracket as mentioned above. Install the pads in the calipers (make sure the end of the pads with the springs is facing down. Install the caliper top-end first by putting the tabs of the pads into the caliper bracket grove. Then rotate the caliper down down into the bracket. The spring clips will compress into the bracket. Insert the pin into the groove while holding the caliper in place. Install the washer and retainer clip on to the pin and you're done.
