under drive poll
Old Mar 4, 2007 | 10:40 PM
rssshen vette's Avatar
rssshen vette
Default under drive poll
I'm one click (Jegs online) away from buying a march under drive pulley set, but I needed to here from some of you guys if under drives pulleys are worth the money. I do some bracket racing on the weekend and thought I could pick up 1 or 2 tenths in the 1/8 mile by adding the pulleys. Cold Air Intake and SLP runners are also on the "to buy list". So are the pulleys worth buying?
Rssshen Vette
Old Mar 4, 2007 | 10:43 PM
hippy's Avatar
hippy
Rssshen Vette
YES
Old Mar 4, 2007 | 10:58 PM
John A. Marker's Avatar
John A. Marker
I believe they are. Buy the three piece set. I would also check out the March web site directly. You will get better information on which set you need and might even save some money.
Kool88vette's Avatar
Kool88vette
Old Mar 5, 2007 | 08:58 AM
black85's Avatar
black85
Yes. I have the March 3 piece as well. I would have picked up a tenth or so, but I left the car in second gear by accident. Still picked up a new record 60' time, and tied for my best e.t.. MPH was down by about 3, so I would have gotten a new best e.t. if I would have selected Drive.
Dave
Old Mar 5, 2007 | 09:50 AM
tequilaboy's Avatar
tequilaboy
I have the March 3 pc. set with the underdrive alternator pulley that is intended for use with the stock belt.
I think its worth it, there seemed to be a seat of the pants improvement right after the installation.
With this set up, I do need 850-900 rpm for the alternator to provide any kind of charge, or the battery voltage begins to get pulled down under 12.6 V. I run an 850 rpm idle speed in my chip, mainly for this reason.
Also, it seams that I go through alternators rather frequently now, maybe 1 every 3 years or so. I do get tired of swapping the pulley everytime.
The 2 pc. may be a better solution for an auto trans car or if you wish to retain a stock idle rpm for any reason.
If you go with the 3 pc. you will always have the option to run either alt pulley, but you will need to get a shorter belt also.
I guess its a question of paying for the extra pulley or an extra belt, or both.
Old Mar 5, 2007 | 10:12 AM
wro87's Avatar
wro87
You might want to look at the ASP site I bought a 3pc set there for less than a march set.
wro87
Old Mar 5, 2007 | 10:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Good mod for racing.
Better bring jumper cables, battery charger or a spare battery.
Old Mar 5, 2007 | 10:59 AM
rickneworleansla's Avatar
rickneworleansla
http://forums.corvetteforum.com/show....php?t=1598960
Old Mar 5, 2007 | 12:07 PM
Steel Breeze's Avatar
Steel Breeze
Hmmmm, I just took a pair of underdrive pulley's (waterpump, and crank) off of my 88. I didn't know they were there. But I never could get belts etc, to fit right. They are nicely machined pieces. I'm not sure rather to sell them or not. http://forums.corvetteforum.com/show...t=Steel+Breeze
Old Mar 5, 2007 | 01:06 PM
wro87's Avatar
wro87
Charging does not seem to be a problem even with the cam install. If you look at the ASP web site they tell you when the alternator will start to kick in and hell who just to keeps theirs running at idle.
GO FOR IT!!
GOOD LUCK wro87
Old Mar 5, 2007 | 04:40 PM
rel3rd's Avatar
rel3rd
I used the underdrive crank pulley only. No issues whatsoever and engine seemed to rev a little quicker. Mine charges fine at idle.
To under drive poll
