is my shift linkage bad?
Old Mar 4, 2007 | 11:12 PM
all show and more go's Avatar
Default is my shift linkage bad?
just bolted up the tranny today(4+3) and it wont go into gear,my pops said it could also be the slave cyl. doesent have enough pressure, somebody help!
Old Mar 4, 2007 | 11:16 PM
JLeatherman's Avatar
JLeatherman
What have you done to it recently? Did you bleed the slave cylinder? Will it go into any gear? Will it go into gear when the car isn't running? Was it working fine before you removed it?
Seems like a lot of questions, but it shouldn't be hard to figure out once you answer them.
Old Mar 5, 2007 | 01:39 AM
jhammons01's Avatar
jhammons01
I would think that there is a problem with Linkage if you can't get in to go in any gear.
Are you saying that you can't get it to go in gear while the motor is off and you are gently rocking the car back and forth?
If that is the case then Linkage.
If it is just not depressing the Clutch when the motor is running then more digging is needed
Old Mar 5, 2007 | 02:24 AM
bogus's Avatar
bogus
if it's the same transmission, it leaked dry... it could be anything.
Old Mar 5, 2007 | 09:45 AM
i changed the throw out bearing, alread blead it, it did before i turned on the car but after i turned it on it wont go into gear even when its off,it was fine before i removed it.
Old Mar 5, 2007 | 03:38 PM
alright guys,i need your help,its teamwork, ineed someone to tell me what is between the slave cyl. that pushes the bellhousing fork,when i looed at mine it had a push rod that was cut and put in there,and thats why i think its not going into gear,help me out!
Old Mar 5, 2007 | 06:21 PM
JLeatherman
There's supposed to be a pushrod from the slave cylinder to the fork. It kinda tapers at the end of that touches the slave. It isn't actually held in by anything but the rubber boot. Lay under the car and have someone depress the clutch pedal and see if it's moving the fork properly.
To is my shift linkage bad?
