transmission?
Old Mar 5, 2007 | 06:40 PM
BlackVette00's Avatar
BlackVette00
Default transmission?
I have a 93 6 spd, with 83,000 miles, shifts fine, runs good, just makes a annoying consistant chirping noise only in 1,2,3 gear when on the pedal, only at wot, other then that its good, what could be that noise? then when I put it in neutral it goes away?
Old Mar 7, 2007 | 03:07 PM
BlackVette00
anyone?
Old Mar 7, 2007 | 03:16 PM
89er's Avatar
89er
I have that symptom on a 1990 that started after the transmission was replaced. I didn't change any of the clutch components because that had been done a few hundred miles earlier. I speculate that it could be the self lubricating pilot bushing. In the old days a dab of grease would be put on tip of the pilot shaft. Basically I am ignoring the sound.
Old Mar 7, 2007 | 03:27 PM
BlackVette00
well I wasnt too sure it was the tranny, but the symptons were pointing too it. But my tranny is running good, all gears are good, clutch feels good, so I can I make the noise stop?
Old Mar 7, 2007 | 04:35 PM
97AGGIE's Avatar
97AGGIE
Maybe the throw-out bearing? Tend to act up/squeal w/high miles.
Old Mar 7, 2007 | 06:22 PM
BlackVette00
idk, could it be the dry-shaft? I know its something rotating, cause I can hear it going in circles, maybe dryshaft,tire area, or tranny?
Old Mar 7, 2007 | 08:52 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Only at WOT???
I don't know what's causing that noise on your Vette but on mine, it's the tires chirping.
Old Mar 7, 2007 | 10:03 PM
89er's Avatar
89er
At one time I had a chirping sound (not tires) that happened when I gave it gas. The problem was hard to find but it turned out to be a u joint in the right rear half shaft. The noise would occur without touching the clutch.
Old Mar 7, 2007 | 11:06 PM
BlackVette00
my car makes the noise only at wot, in low gears, sounds like it coming from behind me like by the wheel area??
To transmission?
