Electronic Climate Control Buttons
Old Mar 8, 2007 | 03:07 PM
Bob88vette's Avatar
Bob88vette
Default Electronic Climate Control Buttons
Have an '88 C4 with the electronic Climate control. The buttons do not seem to respond to the touch. I can change fan speed and warmer and colder red and blue buttons. But trying to change from defrost, to bi-level, AC, seems to be very delayed like push the button wait wait wait and sometimes it changes. most of the time not.
Is this a swap out of the whole control panel or is there a common fix?
Thanks again for all the help
Bob
'88 35th Anniversary #114
'01 SuperGlide
'99 Escort
'06 Exwife (Alimony)
Old Mar 8, 2007 | 03:13 PM
BlackVette00's Avatar
BlackVette00
my car is doing the exact same thing except it will not change only stay on defrost, if you find out the problem let me know, thnks!
Old Mar 8, 2007 | 04:15 PM
JIMBO7's Avatar
JIMBO7
Do an electromic climate control search. There are a couple tips on tech tips also to resolve this problem. (sometimes). I did the go-round with this 2 years ago on my 88. Finally bought a used (working) one on ebay for 100 and all is good since. By the way, I spent over 600 at a local 'vette shop' that told me they could handle this problem 'no sweat'! They were a joke. It was replace parts and hope it works with them.
Try the tips in the search feature or in tech tips first. Good luck. Jimbo
Old Mar 8, 2007 | 09:14 PM
es's Avatar
es
Some times it can be a real simple fix. The contacts in the switches can get dirty or slightly corroded. You can pull the unit out and carefully use electronic contact cleaner and some canned "air" to blow things out gently.
Here in Florida we have a long period from fall through winter and spring where I don't use my AC. The first time I try the climate control after a long layoff, the buttons don't do anything. Everything comes back to life after I push each button a bunch of times. Seems like the movement cleans the contacts. Try this first, and if it doesn't work take the panel out and clean it.
Old Mar 8, 2007 | 10:40 PM
Bob88vette's Avatar
Bob88vette
Thanks for the quick responses. I'll try the contact cleaner.
Old Mar 8, 2007 | 10:43 PM
BlackVette00
let me know if it works, and on my car, when I push the different AC buttons to the vents to the face, only the green light turns on, so i know the button works, so what should I try to look at next?
Old Mar 9, 2007 | 02:17 AM
carson's Avatar
carson
I took my climate control apart and cleaned the cuircuit board where the buttons push down on. Not much to it, hardest part is taking it out of dash. Fixed my hold the button down until it worked problem.
Old Mar 9, 2007 | 02:18 PM
pr1mu5's Avatar
pr1mu5
Mine always seems to come to life when I punch the side of the dash (passenger side) where the unit is... then the buttons work great, for a while.
Cheap fix.
Old Mar 9, 2007 | 09:30 PM
Benny42's Avatar
Benny42
I agree with ES. I disassembled and cleaned mine with rubbing alcohol and a q-tip. It works ok now. Just be gentle with it. benny
To Electronic Climate Control Buttons
