TPS screw size?!?!
Old Mar 9, 2007 | 11:37 AM
kopbet89c4's Avatar
kopbet89c4
Default TPS screw size?!?!
Anyone know the thread size and pitch of this very hard to find aluminum screw?
Old Mar 9, 2007 | 12:39 PM
SunCr's Avatar
SunCr
4.5 mm. You can try Street and Performance www.hotrodlane.cc - Someone around here found something at Home Deport several years back.
Old Mar 9, 2007 | 12:41 PM
Slalom4me's Avatar
Slalom4me
A size or p/n for the '89 TPS screw does not appear to be listed.
However, there is a reference to kits that are supposed to include
the fasteners for the TPS, the IACV and the top plate (Clean Air Cvr).
17110840 ('85-'89) FASTENER ASSORT KIT, INCL #21, #22, #42, #62
17112369 ('90-'91) FASTENER ASSORT KIT, INCL #21, #22, #42, #62
The p/n's are both GM & ACDelco. The 0840 does not come up at
GMPD or RA, but the 2369 does - roughly $16. GMPD calls this
a 'Multiport Fuel Injection Throttle Body Seal' while RA calls it a
'Fuel Injection Throttle Body'
I do not know how the fasteners changed for the '90-'91.
FWIW - the #17111606 TPS sensor kit for the '85-'89 indicates that
the screws and washers (#21 & #22) are included. About $38-$46.
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Forget Ace Hardware... at least the one here, I already tried there.
Those little guys have a lot of 'TPI' on'em.
They like to stick and be drilled out too so be sure and put 'anti-squeeze' on them when you replace them.
Old Mar 9, 2007 | 12:46 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by SunCr
4.5 mm.
4.5? Is this the diameter or possibly a variation of the pitch (0.45)?
Here is a selection of available sizes as per McMaster-Carr. Look under
Metric Bolts
Thread Size
M1.6 | M2 | M2.5 | M3 | M3.5 | M4 | M5 | M6 | M8 | M10
Metric Thread Pitch
.35 mm | .4 mm | .45 mm | .5 mm | .6 mm | .7 mm | .8 mm | 1 mm | 1.25 mm | 1.5 mm
Old Mar 9, 2007 | 01:23 PM
Slalom4me's Avatar
Slalom4me
I need to double-check the pitch, but a 58mm TB here with an
unknown past has two slotted machine screws/bolts with the following
characteristics:
- slotted pan head: M4.5 x .75 x 27mm (1-1/16" long)
(Edit: changed from M4 x .7 x 27 mm (1-1/16" long))
These are magnetic, so they are not aluminum.
Old Mar 9, 2007 | 02:08 PM
Slalom4me's Avatar
Slalom4me
Oops.
SunCr is correct, the TPS bolt/screw appears to have a M4.5 x .75 thread.
Old Mar 9, 2007 | 02:36 PM
Aardwolf's Avatar
Aardwolf
Around here Fleet Farm has drawers of bolts like that.
Old Mar 9, 2007 | 03:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Forget about searching for that bastard size. Retap and use stainless allen heads.
Old Mar 9, 2007 | 04:51 PM
86PACER's Avatar
86PACER
Must be just your Ace Hardware. I picked up a set of these exact screws there. Forgot the size though. Indeed the anti-sieze is a smart idea.
Old Mar 9, 2007 | 07:01 PM
kopbet89c4's Avatar
kopbet89c4
Damn ACE hardware just closed for the day. Maybe tomorrow morning I can grab a few. But thanks for the wealth of info!
Old Mar 9, 2007 | 07:10 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Slalom4me
Oops.
I remember that one inparticular. Where to get em? Dunno. Might be a junkyard only item. There's probably tons of GM cars with TPS sensors with the same screws.
Old Mar 9, 2007 | 09:57 PM
SunCr's Avatar
SunCr
Well, the last new TPS I bought came with them.
To TPS screw size?!?!
