Intercooler plus injection question
Old Mar 9, 2007 | 08:45 AM
silver86's Avatar
silver86
Default Intercooler plus injection question
Looks like I'm going to be installing an intercooler on my ride (I do actually want to bring the boost down from 10 to around 8 psi). I still want to keep my Blowerworks alky injection (Gen III for L-98), but I don't believe the intercooler piping is going to have a good mounting location (angled somewhat vertical in relation to the TB). Anyone know if they (meaning anyone) make mounting plates for the plenum to TB interface for stuff like this?
Old Mar 9, 2007 | 01:41 PM
BLWN BUX's Avatar
BLWN BUX
Silver86
I have a polished ATI I.C. That I never used.
This was designed for a corvette and has a large oval snorkel mount allready so it is easy to hook-up to the TB.
It is currently set-up for a pass. side blower but could be easly fabed to be a driver side. You could have a bung welded in to it for the water alki set up you want to retain.
This IC is probably the easiest addition to you car. All ducting will go over the top of the radiator so you shouldn't need to pull the entire front of your car apart to add it.
Send me a PM if you have interist
Good luck
Chad
Old Mar 9, 2007 | 09:42 PM
silver86's Avatar
silver86
Hey BB, thanks. I would be all over that if I hadn't already agreed to purchase the setup in the For Sale section. My concern with welding in a bung is the angle of dispersement relative to the TB.
Old Mar 12, 2007 | 01:11 AM
Mo_Bandy's Avatar
Mo_Bandy
My personal opinion is that the angle ( speaking about the angle of the gaseous nozzle) really will not make a whole lot of difference...
Mine is actually mounted under the intake to the throttle body. Once ould think gravity etc...
The relility is that with about 100 psi and the turbulance of the intake charge anyway. It really will not make any difference.
Mo
Old Mar 12, 2007 | 12:00 PM
BLWN BUX's Avatar
BLWN BUX
The spray nozzels are stamped 45 deg for discharge angle. However, I have pulled my ducting apart and checked the dispersion pattern sveral times. Mine sprays out like a mist.
Include turbulance in air flow, and distribution should be should be fairly
ballanced at most angles. Top or bottom mount should be good. I would just avoid pointing the nozzel directly twards one or the other TB Butterflies.
Just my opinion as well,
BLWN BUX
To Intercooler plus injection question
