94 won't start
Old Mar 11, 2007 | 10:32 AM
2kvert's Avatar
2kvert
Default 94 won't start
I've read on other posts here that when some of you had problems with starting that it may be the coil or the ignition control module or both. Where are they located and how can they be checked? The car has always started and ran fine but it sat for awhile and the last time I drove it, it ran rough. It has sat again for another month or more and now will not attempt to start. I'm not as familiar with the C4's as I am with the C5's so if someone could point me in the right direction it would help out. Thanks.
Old Mar 11, 2007 | 10:57 AM
geogolf's Avatar
geogolf
Default wont start
first thing is make sure your bat. is fully charged dist is behind water pump did you get the frt of motor wet others will explain more as i dont have opti on my 90
Old Mar 11, 2007 | 12:22 PM
2kvert's Avatar
2kvert
Ok I swapped another coil/ign module into the car and still no fire. How can I check the coil/ign module and what should the plugs leading into them read? I guess I need to trace from the plugs first?
To 94 won't start
