Oil leak
Old Mar 13, 2007 | 11:31 PM
mike's vett's Avatar
mike's vett
7th Gear
Default Oil leak
Hello all i have a 94 c4 my first vet but it has a oil leak on the left side of the engine and it drips on the cat and the smoke well not too good.
is this a porblem with LT1 engines and what is the fix.
Thank you for the help with this problem.
Old Mar 13, 2007 | 11:38 PM
STL94LT1's Avatar
STL94LT1
Could be the dreaded intake gasket leak.
Old Mar 14, 2007 | 12:18 AM
mike's vett
7th Gear
Thank you i will check into that im a old timer engine guy 67 firebirds
is all i worked on but now that im old and my 94 is cool looking to me
time to hit the books.
Thank you for the help.
Old Mar 14, 2007 | 07:42 AM
runner140*'s Avatar
runner140*
Put your hand on the oil filter and check for an oily condiction. Could it be a leak in the oil filter adapter? BTW, 44 is not old, I'm old.
Old Mar 14, 2007 | 01:19 PM
compajd's Avatar
compajd
It could be the oil pressure sending unit. It is located above the oil filter. I am having the same problem. Oil leaking on the cat. (smoking) and coming down the oil filter and the fly wheel cover. It only leaks when the car has been driven.
Old Mar 14, 2007 | 03:06 PM
77vetteuk's Avatar
77vetteuk
Im having that exact same problem too. Got under thare today to try and find whats leaking- had me beat?
Never thought about the oil pressure sender though? Whats the fix for that?
Old Mar 14, 2007 | 03:27 PM
96GS#007's Avatar
96GS#007
The oil pressure sending unit is ***not*** located above the oil filter. That is the oil temp sensor.
Old Mar 14, 2007 | 03:51 PM
compajd's Avatar
compajd
You are correct.
Old Apr 7, 2007 | 07:32 PM
bigalbeco's Avatar
bigalbeco
Cruising
Default Oil Leaks at 70K
I just spent the better part of this Saturday morning fixing that same oil leak on my 94. I've already resealed the intake months ago (seeing some oil behind it), however confusing as it might be, mine didn't leak running on the lift for a half an hour at idle, only after a short drive. I purchased the oil filter adapter housing seal and gasket from GM for $5.00 and after installing them I went for a two mile drive and put the car back up on the lift, so far so good. I then went for a 20 mile ride and the oil leak is now fixed. The oil temp sensor just above the oil filter adapter housing is sealed on the back side unlike the oil pressure sending unit and unless the threads are leaking I don't see how it can leak. As a veteran 35 year mechanic and transmission shop owner, I live for these problems, just wish it wasn't my car.
Old Apr 7, 2007 | 10:30 PM
Brand-X's Avatar
Brand-X
I have an oil leak at the intake. I put new head gaskets in my engine and new heads (AFR-220s) and a ports LT4 intake. changed intake gasket recently and it cured the oil leak for a while and now it is back. just shoot me!
Old Apr 8, 2007 | 09:56 AM
jimmers's Avatar
jimmers
But you will have to do some investigating.
Old Apr 8, 2007 | 06:19 PM
bigalbeco's Avatar
bigalbeco
Cruising
Default Intake leaks
Make sure to use the recommended sealer on the front and rear of the intake or you may end up with an oil leak soon after installing new intake gaskets. GM uses a grey silicone sealer, pn/12346141, comes in a small tube for the extra large gap and do clean it with brake clean first and after you install the intake let it dry at least over night.
To Oil leak
