New distributor cap is buzzing
Old Mar 15, 2007 | 10:09 PM
Lilred87's Avatar
Lilred87
Default New distributor cap is buzzing
I replaced the plugs, wires cap and rotor on my 87 and the distributor is buzzing like the rotor is catching on something. I've taken it off and can't find anything wrong. The engine has a serious miss after 1700 RPM that wasn't there before. Any ideas?
Old Mar 15, 2007 | 10:22 PM
Sam Lam's Avatar
Sam Lam
There four screws that hold the black plastic cap to the aluminum distributor housing. The first thing I would check is to make sure the cap is tightened to the aluminum housing properly. Make sure the cap is properly down (on all four points) and not "cocked" on the housing. If this does not appear to be the case, something is rubbing somewhere. Remove the cap and look for any "rub" marks by the rotor on the inside of the distributor cap. Just some thoughts for you
Old Mar 16, 2007 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is the buzz electrical ?? Maybe a problem with the coil installation ??
Old Mar 16, 2007 | 08:52 AM
RRT vette's Avatar
RRT vette
I would double check everything you have done.
Old Mar 16, 2007 | 09:08 AM
mseven's Avatar
mseven
I agree, I've noticed w/aftermarket caps that the fit is so tight to the case that this is very posiible. (may or may not be the problem but a good place to start)
Old Mar 16, 2007 | 03:06 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Make sure the little SPRING is still on the carbon 'button' that transfers HV from the coil to the rotor button.
They LOVE to fall off while you're working on the cap.
It's so easy to lose them it's redicilous.
Make sure the carbon button is in there too. I've seen folks leave them out.
Another tip is to..... turn on your radio to AM and tune it down as low in frequency as it will go 520~540 kHz and listen for the 'buzzing' sound.
If you hear it then there is something definitely arcing in your ignition system and that's probably what you hear.
This works for bad plug wires also. Doesn't help you to FIND the problem, just helps to DIAGNOSE the problem.
Old Mar 16, 2007 | 09:44 PM
Lilred87's Avatar
Lilred87
Yep!. I took it all apart and neglected to transfer the ground lug over to the new cap. Now it's quiet at least. It's late and will have to wait till tomorrow to fire it up and see if it's still missing. Thanks for all the help.
Old Mar 17, 2007 | 03:41 PM
C409's Avatar
C409
Default cap & rotor
Hey...I had an experience once where the coil mounting screws were a tad long and were long enough that two of them actually broke thru the cap just ever so slightly and caused some serious misfiring since they ground to the coil itself. That one was a real troubleshooting mindbender
To New distributor cap is buzzing
