Electric fan's coolant temperature sensor question
Any idea who, if anyone, makes a coolant temperature sensor that uses a 1/2" NPT thread, instead of the stock 3/8" NPT thread?
When I swapped my heads, they have 1/2" holes where the sensor would go, but when I used a reducer it puts the sensor too close to the header tube IMO...
Will a bushing and a street ell work ?? Just a thought
Not sure. I wanted to try and keep the sensor tip into the head as far as possible, but maybe it really doesn't matter, as long as the coolant touches it...
Can you relocate to another location?
Only has to be in coolant?
Sure, I could do that, just don't see another spot...but the existing wire needs to be lengthened anyway.
I also considered just using a simple ON-OFF toggle switch, so I can manually turn it on or off when ignition is ON, but am afraid I may forget to turn it ON when needed...
On my TFS 195 head I used a ,shortened up ,aluminium fitting,
then i screwed the sensor into it ,it fits ok now.
Be extra careful with that hole if you have TFS.
I hope this works for you.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You need what's called a "face bushing".
This will reduce the thread size down without moving it further out much. Kind of like a helicoil does.
You probably won't be able to remove it though once installed. Unless you teflon tape the outer threads and use something with more friction on the inner threads.
That's exactly what I need. Any idea where to find one?
Any contractor supply house could have one.
I usually just order that stuff from mcmaster.com
By the time you spend 2 hours running around town looking for a 12 cent part, you could have it just delivered to your door. It's basically a hardware store that has every tool/part/fitting/material known to man.
I usually order other stuff also, just so the warehouse guy doesn't feel bad boxing up and shipping just one 12 cent part.
That will work fine, even with an aftermarket sender. The common reducer like I used put the sender out about 3/4" too far (and too close to the header tube) when all was said and done.
It looks like it's about 3 bucks, which isn't bad at all.
Part # 4429K524 1/2" to 3/8" face bushing...
