injector size??
Old Mar 17, 2007 | 12:07 PM
rssshen vette's Avatar
rssshen vette
Default injector size??
What is the size of the stock fuel injector in a 1985 vette?
Old Mar 17, 2007 | 01:07 PM
RRT vette's Avatar
RRT vette
24 lb/hr.
Old Mar 17, 2007 | 01:37 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
22 lb
Old Mar 17, 2007 | 02:38 PM
vader86's Avatar
vader86
Its a 24lb injector, but rated at a different psi than the later ones
Old Mar 17, 2007 | 04:34 PM
rssshen vette
Thank for the response guys. I think I may have one fuel injector leaking(#4cyclinder). I'm considerating installing my original injectors to verify if I actually have an leaking injector. Any suggestion??
Old Mar 17, 2007 | 08:08 PM
Sam Lam's Avatar
Sam Lam
rssshen: consider sending the "old" injectors for cleaning and possible servicing before you reinstall them in your Vette. This will cost your maybe $100 and you will know what you have! I have used Rich Jensen at Cruzinpermance (rich@cruzinperformance.com) and was very satisfied with his services, costs and turnaround time. If you consider replacing you injectors, I would use the same flow rate injectors to avoid other car issues.
Old Mar 17, 2007 | 09:13 PM
rssshen vette
Thanks Sam!! I just looked that the web site. I'll get set up with an appointement. I think the accel injectors I'm using is causing me problems (Spark plug fouling). I'm going back to the original Bosh.
To injector size??
