Regular gas Corvette conversion
Old Mar 18, 2007 | 06:20 PM
89er's Avatar
89er
And to all who want to trade heads, I already have a supply of them - thanks though!
Old Mar 18, 2007 | 06:25 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by VetNutJim
I probably wouldn't say the ECM 'compensates' for different grades of fuel because that may be a slightly inaccurate way to describe the function of the knock control portion of the ECM.
I would say it 'tries' to protect the engine from the ill effects of lower than reccomended fuel octane.
OK You say TOMATO
I say TOMATO.
My point is that some owners feel its necessary to run Premium fuel all the time. The recommended minimum octane for the L98 is 87. Anything less can cause excess knock counts, maybe engine damage.
What component of the engine control system adjusts timing vs knock counts? Maybe its the ECM!
So to assist 89er consideration of changing the compression ratio to use lower octane fuel, I'm suggesting that he merely pump from the "other" nozzle.
It's so easy, even a caveman can do it!
Old Mar 18, 2007 | 07:22 PM
C4Techie's Avatar
C4Techie
Originally Posted by JrRifleCoach
Like I said, the ECM will compensate.
Actually, what you said was, "The ECM will compensate for the different grades of fuel..." See post #6 where you said it or post #7, where I quoted your having said it. Reread post #7 to learn that the ECM can never know the octane rating of the gasoline. If it can't detect "different grades of fuel", how could it possibly "compensate for them???
If your so sure, why don't you post this as a separate thread. I'll bet you'll find your mostly alone in this belief.
Why should I post a separate thread on this? I am simply following up on the subject at hand. That is a statement and an example of how the system works. You might be right about me being in the minority, but I hope I'm not, because that would speak poorly about the number of forum members that understand how the ESC system works.
Old Mar 18, 2007 | 08:05 PM
1Fast7R's Avatar
1Fast7R
OK, so if i don't have knock at wot with say 87 octane then i don't need to buy the better stuff for performance? If that is so then why do they sell 110 at the strip and they do seperate dyno runs with different octane getting different hp #'s?
Old Mar 18, 2007 | 08:07 PM
JrRifleCoach
Apparently you have greater retentive traits than I gave you credit for. If your so sure of yourself, write up your post and start the great OCTANE debate.
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by CentralCoaster
High octane is like extra large pants. Any one can wear em, but it's really only necessary for fat people.
The skinny people can save money and buy small pants (low octane) that suit them better.
A fat person can fit into skinny pants, but might blow a hole in the inseam if any detonation occurs.
Then of course you still have all the skinny kids buying fat pants because they think they're better.
Or, nothing's too good for my baby.
Old Mar 18, 2007 | 08:08 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
110 octane is sold at the strip because idiots that don't need it buy it, and many that do need it that are running lots of boost or very high CRs.
Whose dyno runs are you referring to?
A car with zero knocks on 87 octane should make about the same power with 91 octane or 110 octane.
JR, the subject has been debated numerous times on here, but some people just refuse to believe the facts. I guess if they've been wasting extra $$ for years on high octane, it's a little hard to accept. Of course, if you're testing for knock counts, you should do it on the hottest day with the car as hot as it'll ever get on the street or track.
As far as the ECM, I'm not sure what years have learning ability, if any, but I think it simply retards timing when knock occurs, and then slowly advances it back, you'll feel it when you're accelerating like someone pulled the parachute. The key is knock will occur. It does nothing to prevent knock based on the octane level as your post implies.
Old Mar 18, 2007 | 08:28 PM
JrRifleCoach
EXACTLY! If the knock counts rise, the ECM backs down the timing to compensate. Change fuel grades and the ECM will maintain the highest timing value until knocking appears.
So, the ECM will compensate for different octanes by adjusting timing based on knock counts.
Old Mar 18, 2007 | 08:37 PM
CentralCoaster
Yeah, but the low octane will still knock your motor to death. The ECM will simply delay the inevitable and make the car no fun to drive.
It's like having an electric shock collar on your dog that zaps him everytime he leaves the property, only in this case your dog will never learn, he'll keep running into the street.
As opposed to using the right octane level, the car will hardly ever knock.
Old Mar 18, 2007 | 08:38 PM
C4Techie's Avatar
C4Techie
Exactly.
There is a LOT of that going around.
Old Mar 18, 2007 | 08:40 PM
89er's Avatar
89er
If I lower the compression to 8.5:1 I can let the ECM compensate for when I get a bad tank of regular.
Originally Posted by Steel Breeze
The "Cheap Stuff" is actually more volatile than the "Expensive Stuff".
And lowering the compression will keep it from pre-igniting without spark. Thanks for the feedback that says if I lower the compression I can leave the timing as it is.
Old Mar 18, 2007 | 08:49 PM
CentralCoaster
It'd be easier to buy an ECM emulator from Craig Moates.
You could then have an 87 octane program with reduced timing advance tables, and simply switch between that and your stock program on the fly.
Old Mar 18, 2007 | 09:00 PM
  #33
C4Techie's Avatar
C4Techie
Right "If the knock counts rise". What if they don't? How does the ECM detect "different grades of fuel"? It isn't the fuel the ECM reacts to it is knock counts. In your example of, "Change fuel grades and the ECM will maintain the highest timing value until knocking appears." What additional compensation will the ECM make for one grade of gasoline that has no knock counts, over a lesser grade of gasoline with no knock counts? In other words, if it doesn't knock on 91 octane, and you change to 93 octane how will "The ECM will compensate for the different grades of fuel..."?
Old Mar 18, 2007 | 09:24 PM
  #34
CentralCoaster
Old Mar 18, 2007 | 09:39 PM
  #35
USAsOnlyWay's Avatar
USAsOnlyWay
Old Mar 18, 2007 | 09:46 PM
  #36
JD'S WHITE 93's Avatar
JD'S WHITE 93
Wouldn't it be easier to just dump a bottle of octane booster in it If needed ? I don't think it will spark knock driving it normal anyways.
Old Mar 18, 2007 | 09:50 PM
  #37
BadjerJim's Avatar
BadjerJim
Interesting thread. I recommend contacting Alvin at pcmForLess.com, and have him make a custom chip for your ECM.
Tell him that you need a specific chip programmed for Mexican gas. Tell him the octane available, the particulars about your car, and he'll do the rest. Like spark advance curve, fan temps... all kinds of stuff.
Then when you get back from Mexico, yank that chip and get back to higher octane gas like was intended for your car.
Alvin made a custom chip for my 1990. Part of the question and answer was: "I promise to use 92+ octane gas at all times." That enabled him to program other parameters for the ECM to get the best overall performance from my otherwise stock 1990.
He can do the same for a particular (and short-term) Mexico trip.
Realize that... at some point with low-octane gas (like 84 or less) - no amount of programming is going to help. The simple physics of the compression ratio will mean that the engine will knock - like tap-shoes on a steel staircase. As mentioned earlier, you can get away with 87 octane. But that's just it: you're getting away with it, to the detriment of performance.
That's my opinion, and I'm sticking to it!
To Regular gas Corvette conversion
Old Mar 18, 2007 | 10:00 PM
  #38
89er's Avatar
89er
I program and burn my own chips, that's why I was curious what computer changes are needed. Thanks
Old Mar 18, 2007 | 10:02 PM
  #39
89er's Avatar
89er
It would actually be harder since I have not yet put the heads on the 1990 short block.
Old Mar 18, 2007 | 10:08 PM
  #40
89er's Avatar
89er
I
And it all points to lower compression as the way to go.
