Damn VATS again
www.vatssucks.com - yes it does!
There is no easy fix for VATS.
_________________________________
There is no easy fix for almost anything that breaks on your car!
Instead of wasting your time and energy complaining about your VATS, find out what isn't working right and FIX it, then get on with your life.
I've had far more serious repairs required on my 87, some multiple times. I fixed them or had them fixed and continued driving it every day. If something breaks tomorrow, I'll fix it. If this puny problem is so disabling to you, sell your car and buy a newer one. Older cars are prone to problems from time to time, parts don't last forever!!!!!!
Continued whining without fixing the problem is the mark of an immature person and guess what.....your VATS still won't be reliable. Fix it already and enjoy your Corvette, they are worth it.
The point I was trying to get across is that I can take a car not working because of a mechanical malfunction, s**t happens. But I think it's a stupid design for car to stop working and leave its owner stranded for something as minor as a keyswitch.
If GM had designed it properly there would be a switch, with it's own separate key, that would disable the VATS entirely at the owners discretion. They could have hidden it in the glove box.
Anyway it started up fine again last night. I haven't tried it today.
VATS is very straight-forward on '90 and up cars. There are 4 things that can cause a VATS no-start issue...
1) Bad ignition key
2) Bad ignition key cylinder (due to worn contacts)
3) wiring / connectors
4) CCM
If GM put a separate switch in the glovebox, hidden or not, thieves would know about it practically as the cars arrived on the the showroom floor. That information would be readily available at the library (given it was ~1986 when VATS first appeared), or in the service manuals. Of course even if GM ignored the obvious and tried to "hide a box" somewhere, the first owner who misplaced the VATS key would cry foul and then that approach would be crucified as well. Hmmmm...from a high theft rate to practically 0, lower insurance rates...I think that given the technology of the time VATS was an ideal solution.
Since your IP works, your CCM is fundamentally ruled out....less than a 1 in 1000 chance IMO.
That leaves wiring or the ignition key cylinder which, by your own admission, is a mechanical malfunction that you said you can deal with.
For all the calories wasted on this debate, you could have fixed it by now.
