Rear bushings needed
Old Mar 20, 2007 | 09:14 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Default Rear bushings needed
I want to replace the rubber bushing on the bottom of my rear leaf spring. There's one on each side of the rear leaf. There is a bolt that goes through the leaf spring and on the bottom of the bolt is a rubber bushing then a nut with a cotter pin going through it. I called the dealer and they ordered in the worng parts. They ordered in the bushings that actually go into the leaf spring. Could someone please tell me where to buy these ? I've seen them as part of a lowering kit with different bolts but I like my ride height as is and just want the bushings.
Old Mar 20, 2007 | 09:20 PM
Pete K's Avatar
Pete K
Any speed shop that sells Energy Suspension will carry them. They are urethane though, not oem rubber.
