1987
SuperRam, (portmatched runner/plennum)
Stock base
1.6 Promagnum Roller Rockers, with ARP studs, harded push rods,Guideplates.
stock heads.
Stock cam.
LT headers, and no cats.
+ all the free and small mods.
Would a LPE 211/219 duration and 530/560 lift (with 1.6 rockers) do me any good?
I will change the base to the SR base too, when doing this mod.
that cam would be a great compliment to your current combo. if you have the stock l98 cam, changing to the 219 cam would make a tremendous difference, especially if you include the matching accell base.
i dont think that the 219 cam has any lope to it, i could be wrong.
From what I've seen, the stock heads will support a maximum of about 280 RWHP.
I'd guess you're at about 250 RWHP now, so there is some room for improvement with an intake base and cam upgrade. Maybe 25-30 HP worth. I think its worth it.
For the costs involved, you may want to consider a base upgrade and some better heads, with the camshaft as an option, since you will soon be thinking about better heads anyway....
Base + Cam approximate cost = $800-1000
Base + Heads approximate cost = $1500-$2000
Base + Heads + Cam approximate cost = $2000 ->
My 87 has a Comp Cam with 224-230 duration .512 lift with 1.6 rockers and it lets everyone know its not stock. performance should be very noticeable too.
The cam im looking at is 211/219, yours seem big! Anygood with Stock engine and SR?
Lars, with all your mods so far, don't shortchange yourself. Seriously budget for: heads, the 219/219 cam, and the SR base. Try for find a used base if you can. and you can sell your stock heads and recoup $300-400.
the 211/219 cam would be fine with SR base, ported plenum and large tube runners.
in my 355, the cam does have a noticeable lope -- mild but noticeable. the car shakes slightly at idle. it is in tune. by hearing it there is no way it passes for a stock setup. which is perfect for me.
Change the cam and port those heads--it would be cheap to do that.
maybe, maybe not. the stock heads? $500-700 for a proper port job. hopefully a good source that won't screw them up. another couple hundie for valvetrain component replacements/upgrades. by then you're in aftermarket head territory. as i mentioned, then you can sell the stock heads for a couple hundie back. just my thoughts.
I'm also running a 224/230 cam with my SR. Its a Comp 503 with 224/230 duration at 0.050, 112 lsa, 0.503/0.510 lift with 1.5 rockers.
I think its a good match for the SR and otherwise stock motor. Mine makes peak HP around 5200 rpm and makes good power to 6000 rpm and beyond.
Here's a dyno pull (with a rich tune):
I'd say the power band is between 4200 and 6000 rpm. I like to shift the lower gears right around 6000 rpm which is just over 40 mph in 1st, 60 in 2nd and 90 in 3rd, with my 4+3 and 3.73 gears.
I wanted a cam that would rev-out just a bit so I went a little bigger than the standard 219.
At 850-900 rpm where I usually like to idle, there is only a slight lope, maybe a little crackle.
I can make it lope more of course, if I want to idle it down to 700 rpm.
I need to record some sound clips, I have one, but the quality is pretty poor and you have to turn it up to hear anything. It is not really representative of the sound.
Somebody posted a nice video and sound clip of this cam recently with magnaflows, and it sounded great. I can't recall who it was though.
It was a post entitled something like "here's what it sounds like at idle..."
