Optispark II installation oreientation question
Old Mar 22, 2007 | 11:40 PM
LS-Five's Avatar
LS-Five
East bound and down...
Default Optispark II installation oreientation question
I am sure this quesiton has been asked before, but my DSL is down and I am on dial-up so it takes me too long to search.
I just recently installed a new cam, timing set, and water pump. I have a book "How to Rebuild LT1's/LT4's." In this book the author makes specific mention of the fact that the dots do not need to line up (6 o' clock cam dot, 12 o' clock crank dot) on the crank and cam sprockets to install the distributor. Instead he recommends that the cam sprocket dot and the crank sprocket dot both be at 12 o' clock. The piston will be at TDC at either orientation. Can someone explain why it is necessary to install the distributor in this manner?
Old Mar 23, 2007 | 01:12 AM
Hooked on Vettes's Avatar
Hooked on Vettes
As long as the timing chain is installed properly with the dot on both the crank and cam gear at the 12 o'clock position the cam pin will be at the 9 o'clock position. Cylinder 1 will be at TDC on the compression stroke.
The optispark is driven by a pin on the camshaft. So if the timing chain is installed properly you supposedly can't install the optispark in the wrong position but some people have forced the optispark on and the drive pin wasn't installed in the proper position.
Click on the link below.
http://www.shbox.com/1/cam_timing_ani.gif
Old Mar 23, 2007 | 01:24 AM
LS-Five's Avatar
LS-Five
I agree, but there are two possiblities here. You can have the cam dowel pin at 9 o' clock this would mean that #1 would be at TDC on the compression stroke. Or, you could have the dowel pin at 3 o' clock and #1 would be at TDC on the exhaust stroke. Either way the opti will bolt up just fine. I was just wondering why the author specifically mentions that you should install the opti with the dowel pin at 9 o' clock instead of at 3 o' clock.
Old Mar 23, 2007 | 09:31 AM
LS-Five's Avatar
LS-Five
ttt
Old Mar 23, 2007 | 11:46 AM
STL94LT1's Avatar
STL94LT1
Again, if the timing chain is installed properly, and you don't force the opti on. It can't be installed wrong. Any timing chain position will do.
Old Mar 23, 2007 | 05:06 PM
Jerris's Avatar
Jerris
You have answered your own question. At the 9 oclock position the #1 is up on compression..... where you want the spark.
The relationship between the dowel pin and the opti shaft that turns the rotor inside the cap will automatically orient the rotor so that it is pointing at the #1 spark plug wire, hence fire, gas, compression, start.
Think about it some.
To Optispark II installation oreientation question
