Acrylic top has crack
Old Mar 23, 2007 | 10:55 AM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Acrylic top has crack
I have a crack in the Acrylic top of my 85. I wasn't too worried about it until I jacked the car up yesterday and saw how much flex these cars have. The crack opened up like the Red Sea when I jacked up the front right.
Upon doing a search I've seen two suggested fixes although the threads were very old (2001). One was some kind adhesive from 3M the other was a LORD adhesive. Does anybody know if they've come out with anything better in the last 5 years? What are current members using? Can you use heat to fuse the crack together, maybe from the inside where it wouldnt show?
I put a couple bids for tops on ebay but they don't end for a while and it's supposed to rain tomorrow.
Old Mar 23, 2007 | 11:02 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you are going to relace it anyway repair with clear epoxy. Jack it up to expose the crack and use a toothpick to apply. Let it down to cure. Use vinager to clean off excess epoxy. Don't use the 5 minute type it won't give you time to work.
Old Mar 23, 2007 | 11:07 AM
billybonesmusic's Avatar
billybonesmusic
true, the 5 min stuff is too hot and will be brittle, good point bro!
Old Mar 23, 2007 | 11:12 AM
glide's Avatar
glide
Provided I can get it to open again, you don't think it would push the glue out when it closes back up? Epoxy works on acrylic? Ideally I'd like something I could apply to the inside (with top off) and would kind of melt the acrylic together. But its a good idea none the less. If I don't get any better ideas today, I'll try it.
Old Mar 23, 2007 | 11:17 AM
billybonesmusic
does acetone bond acrylic together again? i know when i fix cracks in guitars, i spread the crack open and apply glue with a toothpick then clamp it back and wipe off the excess. or sand it down with really high grit and polish with compound.
Old Mar 23, 2007 | 11:24 AM
billybonesmusic
i know you can use acetone as a vehicle to thin the epoxy out to drop it in the crack
Old Mar 23, 2007 | 12:32 PM
glide's Avatar
glide
Default Temporary top repair
Upon closer examination, I see additional cracks starting from when I jacked up the front right (twisting the whole car) and the crack "opened like the Red Sea". Sooo, I don't want to try that again. As long as epoxy can be used to bond acrylic, I was thinking of using a Dremal to grind a small furrow along the crack and filling IT with epoxy. Then clean up with acetone or, somebody said vinager? What do you think?
Old Mar 23, 2007 | 12:37 PM
billybonesmusic
vinagar or alcohol acetone might fog it.
Old Mar 23, 2007 | 12:40 PM
Tom Piper's Avatar
Tom Piper
I know the C4 will flex quite a bit with the top off.
But, I didn't think the flex was that much with the top on, because of the metal frame for the top.
I would think the metal top frame would prevent the flexing that would allow the crack to open up as much as you are saying.
Are you sure yout top metal frame isn't weak or the mountings aren't loose?
Tom Piper
Old Mar 23, 2007 | 12:51 PM
BADDUCK's Avatar
BADDUCK
What you are suggesting won't look right or repair it. You are better of leaving it alone. Don't use acetone on plastic. I said vinegar will clean up the epoxy residue (only before it dries). You can do an exopy repair that is pracially invisable if you are careful.
Old Mar 23, 2007 | 01:05 PM
ToniH's Avatar
ToniH
Using epoxy on acrylic? Okey, but isn't acrylic glue more logical choice? Search Google with "acrylic glue".
My acrylic top cracked from front corner 3 years ago. It had a 1.5" crack. I did nothing to it and it didn't change until last summer it cracked big time. Suddenly one morning the crack was 10" long. Went out and bought a plastic top to replace it.
Old Mar 23, 2007 | 01:54 PM
BADDUCK's Avatar
BADDUCK
No, acrylic glue is for bonding acrylic to another substance ie pvc, metal, etc. It never really hardens and remains flexible so the acrylic won't pull away. It's more like caulk.
Old Mar 23, 2007 | 02:39 PM
ToniH's Avatar
ToniH
Well, maybe there is 2 or even more kinds of acrylic glue like there is dozen kinds of epoxy?
http://ozreef.org/diy_plans/techniqu...g_acrylic.html
Old Mar 23, 2007 | 02:51 PM
BADDUCK's Avatar
BADDUCK
Whatever
Old Mar 23, 2007 | 03:30 PM
ToniH's Avatar
ToniH
Whatever
Oh, I am sorry your highness.
Old Mar 23, 2007 | 04:39 PM
Jerris's Avatar
Jerris
You can purchase the proper acrylic bonding agent from any sign making place that makes plastic signs (I dont remenber the brand as it was some time ago). This stuff fuses the acrylic and will hold it as one piece. The epoxies will just flake off once it has cured.
Having done this before I can assure you you will not like how it looks after, however you can sand it smooth and paint it the color of the car. as I did, and it looks just like the fiberglass one and keeps the heat out, for a lot less money.
One good side effect for me is that the glass top gives about 2 more inches of headroom than the fiberglass one, which I need.
Old Mar 23, 2007 | 05:20 PM
BADDUCK's Avatar
BADDUCK
You guys are full of it. I have repaired acrylic with epoxies for years and it works great. I wouldn't have recommended it if I didn't know it will work.
To Acrylic top has crack
Old Mar 25, 2007 | 09:33 PM
glide's Avatar
glide
Could I use a Dremel and grind a tiny furrow along the crack and fill that with the clear epoxy? Or would that weken the top. I'm afraid if it opens up again the crack might spread. Actually I've seen black epoxy too.
Eventually it will be painted if I don't find a deal on a new one.
Old Mar 28, 2007 | 03:19 PM
wacojohnnyd's Avatar
wacojohnnyd
Cruising
Default maybe this?
i have a 94. the top cracked. I drilled a 3/32nd hole at the end of the crack to stop it from cracking. seal the hole with monster glue or whatever. depending on the "shape" of the crack - mine was straight so i got clear vinyl from a sign shop, cut a 1" wide strip, and covered the crack from from of roof to back - my crack was about 10" long. i put a parallel strip so from 3 feet away, they look line racing strips. just a cheap option for you.
Old Mar 28, 2007 | 09:08 PM
Red Dwarf's Avatar
Red Dwarf
Good advice.
