Intake Gasket...
Old Mar 24, 2007 | 11:48 AM
Corvette Chris's Avatar
Corvette Chris
Default Intake Gasket...
Opened my box of Fel-Pro gaskets for the intake manifold this morning. It's set # 47225. Instead of having the rear coolant ports blocked off like the old GM gaskets, it has the open ports. I don't think I can use these gaskets, am I correct?
Old Mar 24, 2007 | 01:35 PM
CFI-EFI's Avatar
CFI-EFI
The rear ports in the manifold are blocked, aren't they? Where will the water flow to, that it shouldn't, through the open port gaskets?
RACE ON!!!
Old Mar 24, 2007 | 01:39 PM
Bulldog Steve's Avatar
Bulldog Steve
How much was that gasket set.....
Steve
Old Mar 24, 2007 | 02:55 PM
Aardwolf's Avatar
Aardwolf
I have been using gaskets with the passages open for a while now, they are doing well. Do a search for fel pro 1256 that should get you more information. When I askked a while back:
http://forums.corvetteforum.com/show...oolant+passage
"small holes on stock gaskets were used to regulate flow to govern temperate.. i used the fel pro 1256, it improves coolant flow throughout the block and heads, keeping temperature more uniform.."
korvette4u
To Intake Gasket...
