TPIS 700-701 Solid Roller Cam Users
Old Mar 24, 2007 | 12:54 PM
Snakeskinner's Avatar
Snakeskinner
Default TPIS 700-701 Solid Roller Cam Users
Im getting to my short list of canidates to replace my current cam
on my combo listed below.At this point I also intend to run it with new
AFR 195 Eliminator heads versus the TFS 195.
I have some questions.
what valve spring will I need to control this cam?
what solid rollers do suggest?
Any problems with excessive knock retard?
Any lifter problems?
Advance ground in? Advance suggested on install?
recommended pushrods?
Headgasket recommended?
BTW I have a Bow Tie Block.
Old Mar 26, 2007 | 04:49 PM
Snakeskinner
Ttt
Old Mar 26, 2007 | 05:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
Try the engine mods section, youll probably get a better response.
Old Mar 26, 2007 | 10:35 PM
85vet's Avatar
85vet
Cruise-In V Veteran
This cam is phenomenal. But the person to answer all your questions would be Corkvette1. I am running the crane extreme solid rollers with no problems.
All parts for motor & build recommended by Corky.
I will see if he will access this post & give you some answers.
Old Mar 26, 2007 | 11:00 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Depends if 143 or 155 spring. If 143 use Kmotion K800, if 155 use Kmotion K1100 (I use these on my 383)
Either Krane or Crowler w/ force pin oiling.
Any problems with excessive knock retard? No
Any lifter problems? No
Advance ground in? Not sure
Advance suggested on install? If your 406 install 4degree adv.
recommended pushrods? Have to wait till you have lifters & heads installed for proper deck height. Expect 7.95 or 8.0 or 8.05
Headgasket recommended? We use marine head gaskets - felpro #17031
All info supplied by corky per my conversation with him.
Old Mar 27, 2007 | 10:25 AM
Snakeskinner
Thanks Corkvette1 & 85vet !
To TPIS 700-701 Solid Roller Cam Users
