Odometer Rollback kinda sorta
Old Mar 24, 2007 | 06:03 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Default Odometer Rollback kinda sorta
I've seen a few threads pop up over the years questioning mileage on cars for sale. Threads on how to tell if the odometer was "rolled back"
I had to fix a minor transmission leak on my own car which got me to thinking what would happen if you just unplugged the vss ? Without the vss plugged in would the miles still add up ? I had a Ford that the speedo cable snapped on and when it did the odometer stopped working along with the speedometer. I've seen quite a few super low mile C4's for sale and this might explain it
Old Mar 24, 2007 | 06:05 PM
Smooth's Avatar
Smooth
Old Mar 24, 2007 | 06:19 PM
JD'S WHITE 93
Originally Posted by Time10
I'm not going to do it, if I were I would have done it while it was on jackstands and stuck it in gear. I'm just wondering if it's really that simple without messing up my cars actual mileage a tenth to find out.
Old Mar 24, 2007 | 06:35 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Computer controled engines use the vss for computing, so various problems (spark adv. etc. depending upon model) can occur if you disconnect it. As long as people well pay for low mileage, there are people out there that will supply it! The other thing, the newer the corvette more likely the older the owner. The older the owner, the less they are driven. And no, putting the car on jackstands won't do it. (how many hours does it take to go 30,000 miles at 80mph?)
Old Mar 24, 2007 | 06:39 PM
JD'S WHITE 93
I was referring to unplugging it while the car is on jackstands and putting it in gear to see if it kills the odometer along with the speedo.
I know your not going to roll the miles off with the car on stands.
Old Mar 24, 2007 | 06:42 PM
Red Tornado's Avatar
Red Tornado
if you discommet the VSS and then try to drive it, you'll go into "limp home mode".
Old Mar 24, 2007 | 07:31 PM
JD'S WHITE 93
O.K. thanks, I was just curious but not curious enough to actually try it.
Old Mar 24, 2007 | 08:26 PM
aboatguy's Avatar
aboatguy
On a related note when I did my gear swap I programed in the 3.45s via tuner cat while the 2.59s were still installed and my car threw some codes on the short drive to the autoshop.
Mike
Old Mar 24, 2007 | 08:46 PM
TA's Avatar
TA
I can't comment on other years, but I can tell you on a 91 the car will not go into "limp home mode". I had the shaft in the VSS snap on my car and other than no speedo/odometer the car ran as it should. It did display a trouble code, though (code 24 if I recall correctly). As a matter of fact, it happened on the way to the track and I ran it anyway. Times were exactly where they were with a functioning VSS.
So buyers beware when I sell my car someday, it probably has 120,660 miles instead of the 122,600 displayed
Old Mar 24, 2007 | 09:30 PM
larryfs's Avatar
larryfs
on the 96 impala ss, u just pull the correct fuse, and it stops counting mileage. no impala owners will talk about it, but everyone knows it. the fuse is labled A/C, but it really controls the digital odometer.
I never tried it on my C4. maybe one day I should go through all the fuses one by one.
Old Mar 24, 2007 | 09:34 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
My buddy had an '86 Fiero, we disconnected some plug(not sure which) but it disabled the speedo and odo. He did it with 33,000 miles since the warranty was still good for another two years. Anytime he brought it in for warranty work(which was often) he would plug it back in. One time he forgot and the tech did some kind of check(maybe he was just BSing us) and said there was over 100,000 miles on the car, the warranty was now void. Dealer said, pay up sucker!
Old Mar 24, 2007 | 10:57 PM
BAM92's Avatar
BAM92
I think the mileage is stored in the CCM. So if you buy a CCM from a car with less mileage and stick it in yours, the lower mileage will be displayed. If you buy a new CCM you will start with 0 miles.
sami85L98's Avatar
sami85L98
Never trust mileage on pre 91 cars, infact if u want to stop odo, than pull the dash cluster turn over and put it on a table, there are 2 wires goes to odo u just need to unlug it, thats what somebody explained to me, now u cant do the same way later than 91 vettes. Dont count on me as some guy told me at vette show. My next vette got to be later 91 or only project only vettes from pre 91.
Old Mar 25, 2007 | 10:33 AM
Tom Piper's Avatar
Tom Piper
However, the VIN is also stored in the CCM.
Therefore, if the CCM was swapped and is scanned with a scan-tool, it will tell you that the CCM is not for that car.
In addition, the CCM stores the option content of the vehicle (like the C68 climate control), and the CCM, being the master computer, controls the communications with those options.
If the CCM does not know those options exist, it won't attempt to communicate with them.
Tom Piper
To Odometer Rollback kinda sorta
