Service Engine Soon, but no codes?
Old Mar 24, 2007 | 08:15 PM
1988redvette's Avatar
1988redvette
Default Service Engine Soon, but no codes?
Hello, I finally have my 1988 back on the road after some time without it. I replaced the ecm, injectors, regulator, pump, egr valve, mat sensor, coolant sensor, egr sensor, cold start sensor, oxygen sensor, throttle position sensor, iac sensor, and plugs.
My car starts right up no problems and idles about 1,200 rpm until it warms up and then it settles down to the usual 700, but it is taking longer to do this.
Upon starting the service engine soon light comes on. I proceed to drive on the highway and get it up to 2000 rpm, and it goes off. If I decrease speed it will come back on. At idle it is on. If I brake suddenly it comes back on.
Car drives fine for the most part. The idle is steady. There are no codes.
Does anyone have any idea what the problem is, and why the light only shuts off at highway speeds with rpms over 1900?
Thank you,
Chris
Old Mar 24, 2007 | 10:16 PM
Sam Lam's Avatar
Sam Lam
Chris: Consider posting this in the tech section as a lot of good people are there and may be able to help you. I do not have a clue what is going on with your car.....sorry!
Old Mar 24, 2007 | 11:03 PM
1988redvette
Old Mar 25, 2007 | 10:23 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
No codes?
My first guess is a vacumm leak somewhere.
Old Mar 26, 2007 | 02:28 AM
1988redvette
Thank you. I appreciate it.
Old Mar 29, 2007 | 11:17 AM
Wheelman's Avatar
Wheelman
Thank you,
Chris
When you attempt to flash the codes on your car, do you at least get the code 12? You should get six code 12s in a row if you have "no codes" and lack of that could possibly indicate an ECM failure.
Old Mar 30, 2007 | 04:54 PM
-js-'s Avatar
-js-
Scan and datalog it at idle until the SES light comes on then a bit more.
That should capture what is causing the issue.
Sounds like whatever it is the closed/low throttle is key to making it happen.
Old Apr 1, 2007 | 03:53 AM
1988redvette
Yes, I do get code 12. I haven't purchased the Turbo Link cable and software yet to scan it.
As soon as I find out more, I will report back with my findings.
Old Apr 4, 2007 | 09:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like your running in "Field Service Mode"
Did you forget to remove the jumper wire in ALDL, after looking for codes ??
Old Apr 11, 2007 | 02:45 PM
RRT vette's Avatar
RRT vette
That is a very likely possibility.
Old Apr 11, 2007 | 02:59 PM
74f100's Avatar
74f100
When I did that on my 89, the check engine just kept flashing while key was on. But its been a little while since I did that.
Old Apr 17, 2007 | 02:23 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Thank you,
Chris
Let's look at the symptoms you describe. The SYS light is generally on whenever you are below 2000 rpm. It comes on when you brake suddenly, (which involves rpms dropping below 2000, or all four high current taillight filimants are suddenly lighting up). No permanent code set.
This is a guess, but you might have an electrical problem that is due to poor power flow from the alternator, or power to the ECM. I would pull the ECM (pretty easy on the 88) and use some "quality" contact cleaner on all of the contacts. I suggest using some DeoxIT from Radio Shack. The DeoxIT ProGold kit has a spary cleaner and protectant. I'd also double check the cleanliness and tightness of the battery connections. Use some cleaner there as well. Check all connections to the alternator. Disconnect, clean and reconnect. All of this will take under 2 hours and cost less than $15. See if that helps.
To Service Engine Soon, but no codes?
