I have A 86 and I think I am having cooling fan problems. Can any one tell me if the cooling fan should keep running after I shut the engine OFF. Thanks
On mine it does turn off when the iginition key is turned off
but will run if it is then turned back (but not all the
way to start position) if the temp is above 212. I
presume it turns off after the coolant temp drops
to some lower value (haven't left it on for that long).
