Broken EGR Valve Temp Switch
Old Mar 27, 2007 | 09:39 PM
ITHZ's Avatar
ITHZ
Default Broken EGR Valve Temp Switch
Asumimg this is the right part in the EGR tube,I found the wire broken.I just got the car last night,test drove,drove home (not in the same day),drove it to work 48 miles and no problems.Took it to lunch and and it kept sputtering (posted on this earlier)and would die at stop lights.If I turned the car off and restarted it would run fine tell I had to stop again.Does this sound like I found the problem(have not had a chance to buy the new yet)?
Old Mar 27, 2007 | 09:56 PM
Slalom4me's Avatar
Slalom4me
My '89 would throw Code 32's intermittantly.
A tip by Gordon Killebrew led me to discover that the threaded insert
had begun to come out of the EGR sensor (1pc - pn# 14087415)
located in the shielded tube that enters the intake manifold on the
passenger side near the distributor.
Aside from the code, there were no driveability issues in my case.
Old Mar 27, 2007 | 10:42 PM
ITHZ's Avatar
ITHZ
The wire is broken off completley.I am not sure how to check for codes on an '87,but there is no check engine light coming on.Were to from here?(I have not replaced the EGR temp switch yet but anyway).
Old Mar 27, 2007 | 11:19 PM
C4boy's Avatar
C4boy
Those EGR temp switches are junk. The porcelean cracks too easily on them. The good thing is they are only about $15.
If it's disconnected, the switch should throw or store a code 32, but my guess is the switch isn't causing your problem.
Old Mar 28, 2007 | 08:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Read this to check for a stored code http://members.shaw.ca/corvette86/No...it%20Check.pdf
The ALCL is above your right knee when sitting behind the wheel.
I have no EGR and the wire to switch is taped and tucked away. No issues for me so I'm thinking your problem may be elsewhere.
Check for a code.
To Broken EGR Valve Temp Switch
