Heated Oxegen sensor?
Old Mar 27, 2007 | 10:38 PM
TPI84GMC's Avatar
TPI84GMC
Default Heated Oxegen sensor?
Has anyone heard of or ran a heated oxygen sensor to achieve closed loop faster?
Old Mar 27, 2007 | 10:52 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
yea
Old Mar 27, 2007 | 11:17 PM
vader86's Avatar
vader86
Yes, I've heard of it. Next question?
Old Mar 28, 2007 | 12:10 AM
RRT vette's Avatar
RRT vette
That is a heated O2's purpose. I have one installed on my 86. If I remember correct....heated O2's came stock on the 94-96's
Old Mar 28, 2007 | 12:21 AM
black85's Avatar
black85
Essential w/ long tubes.
Old Mar 28, 2007 | 12:54 AM
Trog's Avatar
Trog
I don't fully agree w/ the need. I've ran both on my TPIS long tubes. Perhaps I hit closed loop a little faster with the heated unit but I checked & never seemed to drop out of closed with the stock sensor either. If you tune is good, headers are ceramic coated to keep the heat in, that exhaust is hot even at the collector of a header. Feel free to test & put your hand on mine anytime.
Of course Y-LT-MV.
IMHO... if I had to do it over, I wouldn't bother.
Old Mar 28, 2007 | 02:00 AM
BAM92's Avatar
BAM92
Even living in hot Texas, my car would go open loop at idle. It would start smelling like gas. Put scanner just to see. Went with heated o2's and never had problem again. It was an easy fix.
Old Mar 28, 2007 | 03:02 AM
rodj's Avatar
rodj
Same situation here
Old Mar 28, 2007 | 03:15 AM
rodj's Avatar
rodj
Same situation here
Old Mar 28, 2007 | 03:54 PM
JAKE's Avatar
JAKE
Originally Posted by rodj
Same situation here
Me Too! Except no gas smell.
Jake
Old Mar 30, 2007 | 01:58 AM
TPI84GMC's Avatar
TPI84GMC
That sounds exactly like what i want to do. prevent it from going back to open after it goes in to closed on startup. What sensor do i get? running a stock 88 O2 now?? thanks
Old Mar 30, 2007 | 10:20 AM
vader86's Avatar
vader86
Autozone sells one, PN 13190 (thats their PN)
Old Mar 30, 2007 | 10:42 AM
GRX's Avatar
GRX
Here is a complete kit offered at:
https://www.casperselectronics.com/M..._Code=Corvette
Old Mar 30, 2007 | 01:18 PM
vinnies87's Avatar
vinnies87
go to vader86 web site link: http://temp.corvetteforum.net/c4/vader86/
bottom of the page, all you want and need to know on heated 02 sensors and connections, PN's
Old Mar 30, 2007 | 06:31 PM
rel3rd's Avatar
rel3rd
With my new Hedman longtubes, I mounted a stock replacement O2 sensor in the #7 primary tube (roughly 10" from header flange, like stock), after welding a bung for it to thread into. Works fine.
To Heated Oxegen sensor?
