Service ASR
Old Jan 12, 2012 | 05:58 PM
  #41
chrldo's Avatar
chrldo
i had same problem with my 92 coupe , same lights. i disconnected the right front speed sensor to remove inner fenders to change plugs and wires and forgot to reconnect. you might have a faulty wire to a speed sensor on front wheels as they do a lot of flexing. very common on gm cars. you might try removing the wires and bench test it for continuity with a meter while you move it around.
