1998 chevy van engine
Old Mar 28, 2007 | 07:59 PM
tiffsc4vett's Avatar
tiffsc4vett
Default 1998 chevy van engine
Hey guys I just a free engine with very low miles on it.
What would it take to put it in my 84 with the auto trans.
Now Im not going to keep it in there but it something for now.
Im having the old engine rebuilt but this will buy me some time to hook the old engine up.
What do i need to do to make it work.
Old Mar 28, 2007 | 08:12 PM
lt4red's Avatar
lt4red
A carb intake for vortec heads, which is pretty common, and a carb. If you want to keep fuel injection, that will be more difficult. Also an electric fuel pump designed to run low psi for the carb. I don't think the vortec motors have a provision for a mechanical pump.
Old Mar 28, 2007 | 08:35 PM
tiffsc4vett
I want to keep the same setup.
I think I was told I could change the heads from my old engine and flex plate but i dont know.
Old Mar 28, 2007 | 08:58 PM
CFI-EFI's Avatar
CFI-EFI
Use your 1984 heads and complete Crossfire injection system, including the distributor, unmodified. Because the later engine has a one piece rear main seal you will have to use the late flexplate for the correct bolt pattern and engine balance. Piece of cake.
RACE ON!!!
Old Mar 28, 2007 | 09:22 PM
tiffsc4vett
Thanks for the info.
Old Mar 28, 2007 | 11:08 PM
lt4red's Avatar
lt4red
Using the 1984 casting heads over the late model vortecs, especially when you already have the vortecs, is leaving a lot of power on the table you could have had.
Old Mar 29, 2007 | 04:24 AM
Kool88vette's Avatar
Kool88vette
Tell us more about the truck engine. If it's a 350 it should work with the TPI set up. The heads on the truck engine may be OK. You need to be specific about your plans.
Old Mar 29, 2007 | 11:15 AM
CFI-EFI's Avatar
CFI-EFI
Assembly and fit wise, what I said above is correct. But a detail has since come to mind. Your original engine has a 9.00:1 compression ratio. The heads you will be swapping on to the truck engine have 76 cc combustion chambers. If the truck heads you are replacing have less than 76 ccs, the new combination will have less than a 9.00:1 compression and be rather sluggish. It would work, but I wouldn't recommend it for anything but the shortest term. It would be low on power and get poor fuel economy. If you plan on using this for a while, see if you can get the head cc spec on the truck engine.
RACE ON!!!
Old Mar 29, 2007 | 11:33 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
As far as I know they do. I have one but I have no way of verifying exactly what year truck it came out of.
Old Mar 29, 2007 | 02:26 PM
CFI-EFI's Avatar
CFI-EFI
It isn't an issue here, because the Crossfire is going back on, but don't ALL Gen I blocks have the provision for the mechanical fuel pump?
RACE ON!!!
Old Mar 29, 2007 | 03:01 PM
BigLee's Avatar
BigLee
RACE ON!!!
i think the 96-later Vortec blocks got rid of the mechanical fuel pump boss...
Old Mar 29, 2007 | 04:45 PM
Slalom4me's Avatar
Slalom4me
The following casting numbers from the Mortec site might
help identify your engine.
Block
10243880...350ci/5.7L...95-00...2 or 4 bolt mains
Vortec truck (& other apps), roller cam, one pc rear seal
There is also a smaller version
10243878...305ci/5.0L...96-98...2 bolt mains
Vortec truck, roller cam, one-piece rear seal
Heads
10239906 and 12558062...center bolt valve covers and narrow body
"self-aligning" rocker arms.
More information and links in this thread
- L31: Flat or Roller Tappets from GM?
Before beginning to swap heads, consider the chamber volume and
what the consequences will be for compression. The replacement
L31's are shown as having a -13cc dished piston
Compression Ratio : 9.0:1 w/ 64cc heads
Compression Ratio : 8.3:1 w/ 72cc heads
Old Mar 29, 2007 | 04:50 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by BigLee
I think the 96-later Vortec blocks got rid of the mechanical fuel pump boss...
The L31 block does not have a boss for a mechanical fuel pump. It has
a single rear main seal and comes with provisions for a roller cam.
Old Mar 29, 2007 | 05:38 PM
tiffsc4vett
The engine is a chevy 350.I want to use the crossfire setup.Now is there something I can do to the heads to make them work with this engine so i dont get the power loss that you are all talking about.This swap is only for about a year.This should give me the time to build my old engine.
Old Mar 29, 2007 | 06:42 PM
Slalom4me's Avatar
Slalom4me
I believe an inexpensive route to go would be to track down some
23º iron heads with 64cc or smaller chambers.
Alternatively, you might look for some D113 aluminum heads from the
later L98 engines. These have 58cc chambers, but because they are
aluminum, heat dissipates more rapidly. Performance might be
a bit lower than that from 64cc iron heads. The D113 are beginning to
sell for more modest prices than in the past.
The Crossfire is a drawback in this case in the sense that TPI engines
could be adapted to the L31 longblock thorugh a swap to a readily
available lower intake base that fits the existing Vortec head.
Still, considering that your new engine was free, you have a little
budget room for heads presumably. Suitable iron heads should not
cost too much and if the bottom end is in good shape, you may wind
up with a package that you will be happy with for some time to come.
Old Mar 29, 2007 | 07:28 PM
tiffsc4vett
ok now will my cross fire set up work with 23 iron heads.
Old Mar 29, 2007 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
The idea of 64 cc heads is a good one, as long as they are pre-1987 heads. Most all old style intake manifolds can have the center bolt holes reamed out to fit the vertical center holes of the 1987/up iron heads, but since the bolt heads of those bolts are inside of the plenum, you risk a vacuum leak with the Crossfire manifold. The Corvette aluminum heads didn't change to the 1987/up bolt pattern so the year of Corvette heads isn't an issue.
Here is a plan worth considering. If the free engine really has pistons with a 13 cc dish, the stock '84 heads with 76 cc chambers will put the compression ratio in the crapper. The '84 piston is a flat top with a 3 cc valve clearance trough that produces a 9.00:1 compression ratio with the 76 cc iron heads. A set of 128 or 113 heads aluminum heads with their 58 cc chambers will yield a reasonable compression ratio. Next year when you build the stock engine, you can take the aluminum heads into account when you select pistons and continue to use them on the fresh engine. That way you circumvent having to use those "boat anchor", 1984, cast iron, 624, heads.
RACE ON!!!
To 1998 chevy van engine
Old Mar 29, 2007 | 07:48 PM
CFI-EFI's Avatar
CFI-EFI
Your Crossfire already has "23 iron heads". 23° is the angle between the valve and piston centerlines. All production Gen I engines use 23° heads. While correct, adding in this number only serves to confuse the issue for the uninitiated.
RACE ON!!!
Old Mar 29, 2007 | 08:40 PM
tiffsc4vett
I should be able to find the heads in my old mans junk yard. What did they come on,We have some firebirds and some trucks around that have 350's in them.
So im looking for heads with 64cc or lower
Old Mar 29, 2007 | 08:57 PM
CFI-EFI's Avatar
CFI-EFI
Yes, and 1986 and older if they are iron. You will be very lucky if you find any heads with 64 ccs or less. Buying the aluminum heads, as I suggested, might be the best way to go for now and for after the rebuild.
RACE ON!!!
