94 C4 - any easy performance upgrades??
Old Mar 29, 2007 | 11:13 AM
Sailfish40's Avatar
Sailfish40
Default 94 C4 - any easy performance upgrades??
I have a 94 convertible and would like to improve performance without spending a ton of cash or changing the car too much.
Any suggestions? superchip? etc...
Old Mar 29, 2007 | 11:19 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Well, this is a question that lots have asked and there are varying opinions. Most I think will say that there is not much in the way of "cheap" performance improvements that will add real 'rear wheel HP'. That said , you can see that I have added a catback exhaust, increased rear gear ratio, and several air intake changes. Honestly, I am not sure whether I have any significant gain in HP performance. Also since I did not do the work my self, except for air intake, the costs were high for the rear gears and the exhaust install.
I do think for relatively inexpensive costs, adding a KN air filter would help some. Opening the air filter cover with this, also can be done at low cost.
The intake foil that can be added to the TBI is cheap but I dont think it really provides much increase in performance.
I like the catback, I think the aftermarket exhaust is worth the expense to performance ratio. Others can recommend more robust engine mods , and associated costs. Good luck.
Old Mar 29, 2007 | 11:25 AM
Harbinger's Avatar
Harbinger
Originally Posted by bogus
Performance Mods that Don't Work
This is a short list of things that don't work... and could waste your hard earned money!
        Performance Mods that Do Work
                    From FAQ sticky at the top of this section. Basically the cheapest mod you can get that will provide a noticable difference is about $300 if you do it yourself.
                    Old Mar 29, 2007 | 01:25 PM
                    jodyeastman's Avatar
                    jodyeastman
                    What are the beam plates?
                    To 94 C4 - any easy performance upgrades??
