headlight gear
Old Mar 29, 2007 | 12:56 PM
mm174's Avatar
mm174
Default headlight gear
If one of your headlights gets stuck half way when closing and the motor continues to run is it possible that the gear is causing the problem? It also gets stuck in the same spot when opening. I haven't had time to get a closer look at it, just trying to get a few suggestions.
Old Mar 29, 2007 | 02:03 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
What year Corvette? C4s used two different designs during the long model run.
Old Mar 29, 2007 | 02:12 PM
mm174's Avatar
mm174
89'
Old Mar 29, 2007 | 03:40 PM
onedef92's Avatar
onedef92
I suspect your Delrin bushings, then.
Read the TechTips in the C4 Section on this Forum while you wait for your replacement bushings to arrive.
You can order headlight bushings on Ebay, from Eckler's or Mid-America Motorworks (MAM)
Also, check out this article from Corvette Fever magazine.
http://www.corvettefever.com/howto/33098/
To headlight gear
