Is this harmonic balancer good?
Old Mar 29, 2007 | 08:05 PM
Tom 35th anniversary's Avatar
Default Is this harmonic balancer good?
I am transfering my 6 3/4 balancer to my zz4 motor when I noticed this..... the surface is obviously grooved. Its a pretty deep groove. The 8 inch i pulled off is totally smooth. The question is, is this usable or should I just buy a new one?
Old Mar 29, 2007 | 08:12 PM
wro87's Avatar
wro87
You need to figure out which size of balancer you need. Put as far as balancers go you can pick up a new one for anywhere $60-300+ bucks. dont use the one with the cut in it you will more than likely end up with a oil leak. wro87
Old Mar 29, 2007 | 10:40 PM
rklessdriver's Avatar
rklessdriver
You can buy a repair sleeve from any parts house for about $10.00, easy fix.
Will
Old Mar 29, 2007 | 10:41 PM
Pete K's Avatar
Pete K
Will
They save the day.
To Is this harmonic balancer good?
