what is wrong with the ACCEL injectors
Old Mar 29, 2007 | 08:32 PM
fearless's Avatar
fearless
Default what is wrong with the ACCEL injectors
I have posted a previous problem with my car when I hollowed my cats. But I have been reading some other posts and I am just wondering what is wrong with accel injectors you get from summit??? I bought some of these when I first got my car, and installed them about 6 months ago. What is the deal with them?
Old Mar 29, 2007 | 09:05 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Old Mar 29, 2007 | 09:37 PM
John A. Marker's Avatar
John A. Marker
i have 80,000 miles on my set without a problem.
Old Mar 29, 2007 | 09:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
Seems like a higher percentages of failures than most, or at least we hear about them more often. I wouldnt spend money on them again but Im sure there are many sold that are fine. Just my experience.
Old Mar 29, 2007 | 10:23 PM
SunCr's Avatar
SunCr
Mine are fine - about 5 or so years old now but not many miles.
When I bought them, I experienced a problem that others were posting at the time. That was small pieces of plastic flashing under the upper o-rings left over from production. Even though I removed the o-rings and inspected the tops closely, still missed one and when I energized the rail to make sure all was tight, one leaked. Had to unbolt and reinstall, no problems since.
Old Mar 29, 2007 | 10:29 PM
vader86's Avatar
vader86
For some reason their quality is just crap, I've lost count of how many people have had them fail, sometimes just a few months after install.
Old Mar 29, 2007 | 11:30 PM
Kool88vette's Avatar
Kool88vette
I installed mine a year ago, no problems.
Old Mar 30, 2007 | 01:56 AM
tjwong's Avatar
tjwong
I have sold several sets and haven't had any problems. I can't see where they would have any more problems than other Bosch injectors. Accel don't manufacture injectors, they have contractors such as Bosch, or Delphi or Seimens build their injectors. Their latest designs are using a disc valving mechanism rather than a standard pintle valve such as a Bosch style injector.
Old Mar 30, 2007 | 03:19 AM
VenkmanP's Avatar
VenkmanP
I totally understand why you have been steered away from Accel injectors. However, I have some new information that you may wish to consider.
I worked for Accel DFI in the R&D dept. While I was there, the Accel injectors which had developed a reputation for poor quality were completely redesigned. Anyone at Accel would tell you just like Bryan Herter did that the yellow-top injectors are complete garbage.
However, the new injectors have truly turned this around. Manufacturing tolerances and tests have improved significantly. The injectors are much more consistent, offer a better spray pattern, and are not prone to leakage problems and low-speed control issues like the yellow-tops were. I am not sure if Bryan knows this or not. I am sure that the Accel injectors that were sold for many years scared people away from the brand forever, but the issues are truly resolved at this point.
http://impalassforum.com/noncgi/ulti...=011847#000000
Old Mar 30, 2007 | 03:26 AM
VenkmanP's Avatar
VenkmanP
The Mr. Gasket Performance Group is the only stop you need to make for all of your automotive performance needs. We are a manufacturer, not just a re-distributor of products. We conceptualize, develop, manufacture and market our products in our own facilities, where actual enthusiasts are involved in the process first-hand.
http://www.mrgasket.com/
Old Mar 30, 2007 | 08:50 AM
TA's Avatar
TA
I'vr never used them and havr no direct experience with them, but I've read enough bad posts on here about them to steer me to FMS injectors instead.
Old Mar 30, 2007 | 09:52 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I wouldn't use Accel or Python, either.
Old Mar 30, 2007 | 10:56 AM
tjwong's Avatar
tjwong
Originally Posted by Vis Croceus
I've seen their facilities, went on a grand tour a couple years ago when I took on their line. They may have the R&D but not the facilities to manufacture injectors. Now the will do as they say with many other products then go to China and have them built. Such as all their little dress up parts. They do make their own gasket line, but even some of that is farmed out. Take for instance their MLS gasket line, those are ALL manufactured by Cometic.
Old Mar 30, 2007 | 11:15 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
That's interesting.
To what is wrong with the ACCEL injectors
