Ls2/4l65e conversion
Old Mar 30, 2007 | 03:57 PM
Instructor_Mike's Avatar
Instructor_Mike
2nd Gear
Default Ls2/4l65e conversion
Hello folks!!
I have a LT 1 auto, 96 56k miles , considering engine swap, ls2 or 383/425 SBC crate engine. Would like to keep fuel injection, better exhaust.
love gobs of low end torque. Strickly street. All feed back welcome.
what is your opinion?
Old Mar 30, 2007 | 05:59 PM
bogus's Avatar
bogus
don't bother. the conversion on a later car is just too much trouble.
build the LT1. Build the 4L60E. Hell, sell that and get an LT4/ZF6.
Old Mar 30, 2007 | 06:17 PM
comp's Avatar
comp
Old Mar 30, 2007 | 10:36 PM
CoronaL's Avatar
CoronaL
either have your current motor built or you can do the swap and I believe we can get the stock IP to work.
I'll need to put my words into practice though with my swap that will occur sometime this year.
Started off buying parts like gangbusters only to have my funds pulled back a bit by reality.
Have to slow my motor build down a bit so later this summer or fall I'll start pulling my motor/trans once the LS6 I bought is built and ready to put in
Old Mar 30, 2007 | 11:03 PM
bogus's Avatar
bogus
stock IP is only a fraction of the issue... what about the ABS and ASR?
Old Mar 31, 2007 | 12:02 AM
CoronaL's Avatar
CoronaL
if I port in the VSR data and the ecbm reads rest of sensors I think ABS should work. Dunno about ASR, but tbh ASR sux anyway. I could do without it. I'll keep it if I can, but I won't be heartbroken if I can't
Old Mar 31, 2007 | 01:32 AM
bogus's Avatar
bogus
the ASR is the cool. It keeps minor highway and street incidents from becoming major. I use it on the street all the time. And around here (LA, CA), whenever it rains, the roads are slicker than ice.
You won't get the ASR working, but the ABS might. Your best bet would be to swap to an earlier computer.
The VSS on the LTx is different, too. It sends a different signal. I don't remember the specs right now.
Old Mar 31, 2007 | 11:12 AM
excessive81's Avatar
excessive81
i will be doing the same swap this winter i hope. building a forged 6.2 for my c6 then swapping the whole ls2 into the 90 . i am looking to run a piggy back computer to run the motor....fast makes them. 400hp and 400 ft lbs...oh what a feeling!!!!! actually it feels slow to 700(800+ then) but what you gonna do?
Old Mar 31, 2007 | 12:32 PM
bogus's Avatar
bogus
you are lucky that Indy doesn't have emission testing...
FAST piggy back will allow for proper CCM operation? Is the FAST the engine controller? Talk to me.
Old Mar 31, 2007 | 01:05 PM
CoronaL's Avatar
CoronaL
i was under the impression that both are 4k pulses per mile
To Ls2/4l65e conversion
