275/40r18
Old Mar 30, 2007 | 10:45 PM
stubby's Avatar
stubby
Default 275/40r18
Hi all....
I've already run some searches in the hopes of finding an answer to this question. Lots of information on c5's and c6's, but did not find anything on a c4.
My question is this: Will 275/40r18's fit at all four corners of a 1992 coupe? Has anyone done this and if so, were there rubbing issues?
Thanks very in advance for any help you are able to provide.
Old Mar 30, 2007 | 11:13 PM
doug_dayson's Avatar
doug_dayson
I believe you'd want 275/35/18's, no?
Originally Posted by stubby
Hi all....
Old Mar 31, 2007 | 08:51 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I believe your '92 came with 275/40 17 tires. These tires would have an overall diameter of approx. 25.7 inches.
To compare:
275/40 18 = approx. 26.7 inches
275/35 18 = approx. 25.7 inches
As you can see the 275/35 18 would be the best choice when moving up to an 18 inch rim. This would keep your speedometer accurate also.
Not sure if the 275/40 18 would cause any rubbing issues or not, but since it's an inch taller it might.
Old Mar 31, 2007 | 01:42 PM
VenkmanP's Avatar
VenkmanP
Hi all....
Tons of people run 275-40-18 (stock C5 rear) on the C4. Most of them in the rear, but some on all four corners. Never heard of a problem.
Old Apr 1, 2007 | 01:45 AM
stubby's Avatar
stubby
Thanks for the replies. They will certainly help with the decision making
Old Apr 1, 2007 | 02:02 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Hi all....
Just for grins, ran search and found 8 posts of your tire size....
Old Apr 1, 2007 | 05:17 PM
L71Maynard's Avatar
L71Maynard
My '92 had 275/40/18s on the car when I bought it. It did rub in the front. When I bought new tires I went with 285/35/18s and there have been no rubbing.
Dave
Old Apr 1, 2007 | 10:27 PM
DVNCI's Avatar
DVNCI
285/35/18's on front - no rubbing but does steer heavy
To 275/40r18
