power coil upgrade
Old Mar 31, 2007 | 11:10 AM
motownmego's Avatar
motownmego
Default power coil upgrade
I have a 89 and am changing the spark plugs to ngk iridium also going with taylor 8mm wires is i worth adding the hypertech power coil upgrade when doing this?
Old Mar 31, 2007 | 11:17 AM
Aardwolf's Avatar
Aardwolf
Not unless your coil is bad or if you are going to add mods to run much higher RPM or forced induction. Stock is fine. If the cap etc is old that'd be worth doing, and perhaps checking the heat sink compound under the module.
Old Mar 31, 2007 | 11:24 AM
excessive81's Avatar
excessive81
started my intake gasket fix and was surprised to find one of these under my cover. was thinking the same thing when i saw them in a catalog. saved a hundo!!!! i got 8 mm wires already to so what plugs should i run with this set up. and should i use factory gap?
Old Mar 31, 2007 | 11:25 AM
motownmego's Avatar
motownmego
well thanks for the help i did a search and couldnt find any thing on the power coil upgrade. The dist. and everything is the original but if upgrading it isnt going to make a difference in performace i will probaly pass.
Thanks for the input
Old Mar 31, 2007 | 11:29 AM
c4cruiser's Avatar
c4cruiser
For a stock motor, the stock coil should provide all the current needed to fire the plugs if they are gapped to the correct setting.
If you haven't bought plug wires yet, look at the MSD 8.5mm SuperConductor wire sets. There is less resistance per foot and the price should be similar.
Get a good cap and rotor with brass contacts instead of one with aluminum contacts.
When you install the new plugs, lightly coat the threads with some anti-sieze compound. Remove the old plugs when the heads are cold otherwise you can risk stripping the threads in the cylinder heads.
Old Mar 31, 2007 | 11:48 AM
Aardwolf's Avatar
Aardwolf
Spark plugs, get what is on sale. There are many gimmick plugs out there that are a waste of money. Stock gap is good.
Old Mar 31, 2007 | 12:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Stock everything as far as ignition goes is fine for these. I wouldnt get the cheapest set of plug wires nor the most expensive, either.
Old Mar 31, 2007 | 09:02 PM
motownmego's Avatar
motownmego
well thanks for all the info i think i will stick with the stock cap
To power coil upgrade
