ZF Option
I will look for the the spread sheet that has what all the 96 codes are. I recieved this information from the GrandSport Registry web site for 96 LT4 C4's. GM only used the ZF for 6 speed manual trans so it is a double code
When GM went with the 6 speed (ZF)in the late 80's they may have listed the codes different.
Here is what I think would be a good explanation for it:
Having both codes is one way of more efficient inventory management
MN6 = 6-speed transmission.
ML9 = ZF6.
It just so happens that the ZF6 was the ONLY transmission available on the C4.
But auto manufacturing (or inventory control) is a very complicated procedure. In this case, they were easily prepared to use an alternate 6-speed transmission if one was available or designed.
As SurfnSun said, the MN6 code is still used on the C5 and C6. It just means they have a 6-speed transmission but no ZF6, so the actual transmission code is something else.
Oh yeah, there could even be some corporate political issues involved too. Remember GM is a very large and complex organization
However, in all fairness, the LSx is putting out quite a bit of power, but so are many 383s, ZR1s and Callaways.
It's also much more common than the ZF6 in our cars, cheaper to build, lighter, easier to find replacement parts for, and has 10 times the clutch options we do.
Ya, sounds like it sucks to me.
Whats poetic is that you shot your mouth off when you didn't know what you were talking about.I posted a page from my parts book, and I have provided a link to the Forum's own speedo chart where all the six speeds are listed as the ML9. I have a C4 parts book, 1984 through 1996, dated March, 2000, on CD that lists all of the C4 six speed transmissions as having the RPO number of ML9. I am unable to copy from that CD. I don't know what "MN6" is or where it came from, but I see no deviation from ML9 being the RPO code for the C4 six speed trans. Could it be a model number ZF uses for that trans? I WILL admit I'm wrong, if I am.
I have some responses for some other comments made, but lets let sleeping dogs lie.
RACE ON!!!
Now that is Bogus information. Pun intended.
Could bind ??
I do know what I'm talking about. I posted backup for my statement. I can, and I will, admit I am wrong, if it can be shown by a greater authority, than the often in error, bogus, that I am.
RACE ON!!!
ML9=ZF 6 Speed trans
This is my RPO codes for my 96 LT4 ZF 6 Speed manual.
Codes that are under the lid behind the passenger seat that holds the owners manual. I checked these 96 codes.
Have a Nice Day.
MN6 = 6 speed manual transmission car, All Corvettes since 89 use this as the manual tranny option.
ML9 = part designation. ZF in this case, as listed on your sheet.
RACE ON!!!
