ZF Option
RACE ON!!!
RACE ON!!!
RACE ON!!!
Well then youre wrong.
http://forums.corvetteforum.com/showthread.php?t=956104
poetic.
The T56 is made by Tremec. It doesn't suck, it just isn't a nice as the ZF6. It also does not easily fit into a C4.
There are 2 versions of the ZF6. The early "Black Tag" version, 1989 to mid-1993, and the "Blue Tag" version is from mid-1993 to 1996.
The colour literally means the tag is black or blue.
The differences are:
Black tags are made in West Germany by ZF.
Blue tags are made in Alabama, by GM, under license.
Black tags are rated at 450 ft-lbs.
Blue tags are rated at 400 ft-lbs.
Black tags have less angle on the first (and second?) gears.
Blue tags have more angle on the first (and second?) gears. This was done to help quiet the gear noise (whine).
It is generally accepted that the Black tag is better, but for normal street use, the Blue tag is just fine. Besides, a Blue tag can be rebuilt to better than Black tag standards (it just costs a lot!).
For more specifics, check out www.zfdoc.com.
Also, www.c4guru.com - Changing ZF6 Fluid has some details on how to maintain it.
poetic.
Also there is this CF page. It shows the six speed RPO listing for all the years it was offered in the C4. Regardless, we agree that it ISN'T ZF6.
RACE ON!!!
However, that link you so eloquently dissed, was composed by me with source data from a number of individuals, plus, confirmation from Mike Antonick.
With that said, I grabbed my 2003 copy of the Corvette Black Book, and from 1989 to 1996, the book lists the option as "MN6, 6-speed Manual Transmission."
I have nothing else to say on this topic.
The only thats is pathetic is that you can't admit to being wrong.
Whats poetic is that you shot your mouth off when you didn't know what you were talking about.Like I said....go find a console tag of a 6 speed car. You'll see MN6 on there...regardless if you like it or not. I have a pic from a 90 car, I just need to find an 89.
