ZF Option
There's nothing specific about trans type. There's no reason it could not be rolled over to the C5, or a 1-ton delivery van.
Hmmmmm
From CamaroZ28.com- 1997 RPO list.
MM6 Transmission, Manual, 6-Speed, Borg-Warner, 85mm, 2.66 1st, 0.50 6th, O/D
MN6 Transmission, 6-Speed Manual (Merchandising Option)
Looks like C5's do the same thing. Im sure its all speculation tho
Im guessing the system dates back to the 60's when you had multiple manual transmission options.
So lets use some logic, break this down, and put it to bed.
C4 = MN6 + ML9 = ZF6
C5 = MN6 + MM6 = T56
Fbody = MN6 + MM6 = T56.
Anyone seeing a pattern here?
CFI-EFI is correct.
So are the rest of us.
MN6 refers to a 6spd. That's all that matters.
ML9 refers to WHICH 6spd, in this case, the ZF6.
ZF6 is just just shorthand for the ZF 6 spd manual. I dare ANYONE to find this info on an RPO list or decal.
I come back to what I said a few posts ago, the way the C4 was built, the body assembly was built on one line, and mated to the driveline. So the body folks would need to know which pedal set and CCM to install.
I think it's time for this thread to be locked.
Ask me why I care. Because some of you shoveled s*** in his face and went Lord of the Flies on him when you thought he was wrong.
I have the luxury of saying this because while I thought I knew the answer, I wasn't sure, and didn't try to shove it down anyone's throat.
What are any of you defending? All the facts are there in plain sight now.
RACE ON!!!
In my mind its a technicality, but if you want to be absolutely correct then terminology is an issue.
MN6(the six speed option code) triggers ML9(the ZF trans). I never said he wasn't correct about ML9 being ZF.
That is an incorrect statement.
