What shift kit? need advice.
Old Apr 2, 2007 | 10:17 AM
Lars87's Avatar
Lars87
Default What shift kit? need advice.
I want to ad a shift kit on my 87 Coupe. I have made aragments with the local shop, that i will buy the kit, and they will install it for me.
I want tighter and faster skifts, less clutch "slip" at WOT acceleration.
My car has 90k miles. Had the filter and oil changed 500 miles ago, NO "dirt" debris in the oil at all. Mechanic said it looked quite good.
So what kit to go with?
As for instalation, I dont want the tranny removed from the car, or any holes drilled etc.
Old Apr 2, 2007 | 10:27 AM
Aardwolf's Avatar
Aardwolf
The kits I have used, all needed drilling. Only in the seperator plate though. The transgo kit is nice but expensive. I am very happy with the TCI kit that I installed in mine. What ever kit you get, make sure to get a new seperator plate, the kit may not come with one. Also this is a good time to add a drain plug to the pan, put in a better pan, or put in a trans. temp. gauge.
Old Apr 2, 2007 | 10:49 AM
sami85L98's Avatar
sami85L98
when pete k built my transmission and i decided to go with transgo shift kit stage 2, pete has to drill holes in separator plate and they will be permanent, u dont have to buy another plate b/c u will love it, transgo kit involves quite a bit of work, pete drove my car and he love the shifts and decided to go with his own transmission, he usually uses B & M all these years due to its simplicity to install and cheaper than transgo, also if u go with B M kit u dont need to drill any holes (conform this to pete k though).
At the same to upgrade pan to 2 qrt deep pan, it comes with drain plug and fin tubes inside the pan which results in another 10 deg off in temp. But its an option.
Old Apr 2, 2007 | 11:04 AM
Aardwolf's Avatar
Aardwolf
The seperator plate gets very very worn out at the check *****.
Old Apr 2, 2007 | 11:29 AM
Kool88vette's Avatar
Kool88vette
This is the kit that I had installed. It firms the shifts but not to hard. At WOT it shifts later and hard. A transmission specialist can program it to fit your needs. I was due for a transmission service so I had them do everything. http://cgi.ebay.com/ebaymotors/Perfo...mZ180096081784 I think I paid about $80.00 at auction. The buy it now price is a little high.
Old Apr 2, 2007 | 11:52 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I have the Transgo in my 93...I went with the "Full Race" version since I drag race so much...at part throttle the shifts are a bit harsh..BUT...at WOT the shifts are lightening fast and smooth as silk...the tach needle hardly drops at all it shifts so fast...
Old Apr 2, 2007 | 12:09 PM
Lars87's Avatar
Lars87
great! how was the install?
Did the kit include everything needed?
Old Apr 2, 2007 | 12:10 PM
Lars87's Avatar
Lars87
what the difference between these trans-go kits
Shift Kit700R4 Stage 2 & 3
700r4 Transgo Valve Body shift kit, sk700
Old Apr 2, 2007 | 12:31 PM
sami85L98's Avatar
sami85L98
i bought 2 & 3,
Old Apr 2, 2007 | 12:40 PM
Kool88vette
Here's a kit for $81.00 . (T74171) I think this is what you want. The transmission specialist can make it shift as hard and quick as you want. They adjust it by adding spacers to your servo and make it shift hard. They can change your govenor weights and make it shift later. They also change the stock springs. I told the specialist that I wanted firm shifts. He made them so hard I was afraid I would break my neck at WOT. I had him adjust it again. Now it good for the street and strip. The shifts get progressively harder as you apply more throttle. It also shifts at a higher RPM.
http://www.bulkpart.com/Merchant2/me...60-700R4vbkits
Old Apr 2, 2007 | 12:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might ask your tranny guy if he can raise your WOT shift points by shaving a little from the small weights within the governor.
Old Apr 2, 2007 | 02:09 PM
sami85L98's Avatar
sami85L98
Thats exactly pete did mine, when i bought brand governor sonnax 730 just like GM governor, and pete shaved some weight if i remember he shave to 10 gms that gives me shift point later like 5000 rpms approx,
instead of grinding some weight u might install smaller weight and softer springs but this one sells for 40 bux, so he just grind it to make shift at later points.
Old Apr 2, 2007 | 02:43 PM
Pete K's Avatar
Pete K
The transgo kits require permanent mods to the valve body. The v/b must be drilled to cross link passages.
Old Apr 2, 2007 | 02:48 PM
Lars87's Avatar
Lars87
thanks
is their a more simple kit you could recomed, thats more easy to install, and dosent require any holes etc drilled?
Old Apr 2, 2007 | 02:51 PM
Pete K's Avatar
Pete K
The B&m kit works by locking the accumulators with spacers. It is primative in design, but works ok. B&M kits have a reputation for breaking drivetrain parts, but I have never seen any evidence of this.
The B&M kit will require drilling the seperator plate, therefore I recommend buying a new one with the kit. This way, it is reversible if you choose.
Old Apr 2, 2007 | 11:06 PM
Kool88vette
The B&M shift kit makes it shift too hard. That's not good. I had a B&M. It would chirp the tires in second even at partial throttle. It would bang hard always. I found it annoying. It didn't change the shift points. I like the Transgo.
Old Apr 9, 2007 | 04:07 AM
PBA's Avatar
PBA
I combine the two TransGo Shift kits to get the smooth 1-2 part throttle shifts and firm WOT shifts. This is with "B" or "A" accumulators in the vavle body. If you have the "M" accumulator, then the TransGo Junior Shift kit is not needed/added here, and do not add spacers to the band adjustment, or take out the springs and snap ring if you want a smooth 1-2 part throttle shift. If the 1-2 WOT shift is not firm enough, then you can put in a slightly stiffer spring in the 2nd gear accumulator housing. You can have smooth 1-2 part throttle shifts, and firm WOT shifts if done correctly.
To What shift kit? need advice.
Old Apr 9, 2007 | 12:37 PM
Wheelman's Avatar
Wheelman
I have the Transgo Full Race on my '89 as well. The shifts are quick and smooth and very firm at WOT. I love it.
Old Apr 9, 2007 | 12:51 PM
anesthes's Avatar
anesthes
Thats kinda what everyone said when I did mine. I went with the full transgo. Took about 6 hours to do the whole thing on a bench. Fun stuff.
The snap ring for the low/reverse valve tricked me. I thought I had it in the right groove the first time but didnt. Had no reverse. On inspection, I got it right the second time and all is well.
-- Joe
Old Apr 9, 2007 | 01:56 PM
Pete K's Avatar
Pete K
-- Joe
I have run a b&m kit in my vette for the past 14 years and really did not dislike it until recently. I have a fresh trans on the stand now. Sami85L98 was kind enough to send me a transgo 700 2&3 as a gift and I did install it on the new trans. I will give an honest, objective comparison after I install it.
There is a popular thrans builder on the East coast that absolutely hates the transgo stuff and swears it tears up transmissions. I will run the nutz off mine at the strip for a year or 2 and tear it down for inspection.
