Rear C5 conversion?
Old Apr 2, 2007 | 01:12 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Default Rear C5 conversion?
I know about the front conversion, but is there a C5 rear conversion? I've searched and can't find anything
relevant....
Old Apr 2, 2007 | 01:17 PM
Aardwolf's Avatar
Aardwolf
I've seen it a few times, you could search in the road racing section. You won't need larger calipers in the rear unless your really doing some serious road racing.
Old Apr 2, 2007 | 01:31 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Good golly that's come nice 'bumpers' in your avatar.
Old Apr 3, 2007 | 02:49 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Old Apr 3, 2007 | 03:39 PM
Mojave's Avatar
Mojave
relevant....
C4 rear brakes are fine. The C5 stuff is very similar to the C4 stuff as far as caliper specs. Dealing with the parking brake will be a pita.
I would say unless you have exceeded the abilities of the stock rear brakes to leave them alone.
Old Apr 3, 2007 | 04:14 PM
comp's Avatar
comp
Old Apr 3, 2007 | 04:56 PM
93-383's Avatar
93-383
I guess from the previous posts you are talking about the c5 brks not a conversion to the rear mounted trans that c5 has wich would be difficult if not impossible. Although it would shure balance out the car
To Rear C5 conversion?
