smog pump delete thoughts
Old Apr 2, 2007 | 11:47 PM
evmlarry's Avatar
evmlarry
Default smog pump delete thoughts
Hey all,
I have a check valve that snapped in half (corrosion) on the air line that runs to the cat. When going to remove it, the tube going to the cat twisted on me (backout wrench slipped). D'oh!
I know many of you have deleted the A.I.R. pump, could I actually just run that air hose straight down and not affect my emissions? I'm thinking serious about getting the pulley now after this, but I wanted to make sure that I'm not about to do something bad to cause failed emissions until I get the delete setup.
Thanks for your thoughts!
Old Apr 3, 2007 | 12:11 AM
evmlarry's Avatar
evmlarry
Errr... let me add a little to it.
I intend on leaving the whole system hooked up temporarily... will leaving that one portion not connected to the cat cause issues in any way?
Just wanting to save up a little cash for the pulley. This is on an 85.
Old Apr 3, 2007 | 01:58 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cat pipe
I have a cat pipe with the check valve for $45 plus shipping if you are interested. If Texas does under hood inspections and uses a mirror for under car mods, you are sunk.
Chris
Old Apr 3, 2007 | 02:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Make sure and plug the air tube on the cat. The rest doesn't matter. You can just leave it there. If the smog pump is pumping into an empty pipe in the engine compartment, you'll hear it, so either run it out the cat tube, gut it, plug it, or unhook the diverter valve harnesses so it pumps out the muffler by the waterpump.
Old Apr 3, 2007 | 02:14 AM
evmlarry's Avatar
evmlarry
Chris
Consider it a deal! PM sent.
Thanks guys for the input.
To smog pump delete thoughts
