1995 LT1 No-crank
You said you have a new key have you checked the resistance of the "chip" and compared both to make shure they are the same?
If '95 is wired the same as my '94, the fault could be in the ignition switch, starter enable relay, starter solenoid, CCM, clutch safety switch (manual trans), neutral safety switch (auto trans), crank P/N clutch fuse, or any of the associated wiring and connections. This is, presuming of course, that your battery voltage remains at or near the 12.8 volts you measured while you're trying to crank the engine.
Here's a hand-drawn sketch of the crank circuit for my '94:
The source of the 12v for this circuit is the ignition switch (again, presuming that you have a solid 12v getting to the switch from the battery). The switch then feeds that 12v to both the start enable relay's contacts and to the start enable relay's windings via the crank P/N clutch fuse and clutch/neutral safety switch. The far side of the start enable relay's windings is switched to ground by the VATS section of the CCM. If the start enable relay kicks and feeds current to the solenoid, and the solenoid still won't kick, the solenoid (or the connection to it) is faulty.
If you can safely get under the car, measure the voltage across the solenoid's start post and chassis ground while somebody tries to crank the engine (make sure they know to stomp the clutch to the floor or put the car in neutral/park). If you get 12v at the start post, but the solenoid still won't kick, you need a new solenoid. Easy fix. If you're not getting 12v to the solenoid, you need to chase the fault back to the source.
If you need to get the car started once to avoid a 200 mile rollback ride, push start it if it's a manual trans. If it's an automatic, and you can get under the car safely, you can jumper 12v to the start post of the solenoid (make DAMNED sure the car is not in gear if you try this!!!).
Best of luck with it.
Be well,
SJW
The only other thing I can think of is the neutral safety switch.
Years ago I had an occasion where the engine wouldn't crank with the gear shift selector in PARK but it WOULD start with it in neutral.
Hope this helps.
Jake
Be well,
SJW
That TSB indicates the CCM was a problem on some '95 Corvettes and would prevent starting.
The solution was to replace the CCM.
Here's the description:
Make: CHEVROLET
Model: CORVETTE
Year: 1995
Service Bulletin Number: 01053
NHTSA Item Number: 39336
Summary Description:
INTERMITTENT OPEN GROUND ON VATS CIRCUIT OF THE CCM CAUSING VEHICLES TO EXPERIENCE A NO CRANK CONDITION. *TW
Here's the link:
http://www.corvetteactioncenter.com/....php?qstId=151
Tom Piper
12.8V is actually just above the defective battery borderline of 12.6V and normal charged battery should be 13.6V+- a .2. Next time check battery voltage before you even try to start it. Simply turn on the key and read the voltage on the gauge. To drain down to near zero that quickly would make the alternator a prime suspect, but bad cables and connections also need to be considered. Hope this helps.
AND WOULD SOMETIME WORK. I RETURNED IT TO THE STORE WHERE A CHECK REVEALED IT WAS A OPEN RESISTOR. NEEDLESS TO SAY THE VATS DID NOT LIKE IT AT ALL CHECK YOUR KEY. GOOD LUCK
I replaced the starter and haven't had a single recurrence. I know you said your starter is only 1 year old, but still . . .
Just trying to help.
Jake
And this sure sounds like a VATS problem; worn contacts in the igniton switch cylinder. The good thing is that the part is only around $45....the bad....takes awhile to replace.
I suggest measuring the key resistor pellet, finding out what the nominal value should be from a list of VATS key codes and then inserting a resistor across the connector from the ignition switch, under the dash. You will then have to get a new key without the resistor to see if the car starts everytime. All of this just to check if its the contacts in the cylinder are worn or not.
I do not recommend by-passing VATS other than a test.
Be well,
SJW
To pull codes on a 95 you need to jump pins 12 and 4 then turn the ignition on. If you can do that it's probably not your computer.
Good luck.
I first thought battery and since I was leaving Texas for Indiana in the heart of winter, I decided to up the CCAs, so I bought a new 720 CCA battery from AutoZone. Problem persisted.
I then ordered a new starter and after installing it I haven't had a single problem. I suspect it was the solenoid.
Jake
Oh really.....so you can jumper pins and get the codes without a reader....well...I'll be....learned something new.
SJW,
I missed the fact that the security light did not come on. But anyways, if it was the contacts in the switch...a spare key would not make any difference...right? But if the spare key worked everytime, then would not the problem be the key or rather the resistor has either changed value and is now out of range or the contacts on the resistor are worn?
How tight a tolerance does the VATS allow on the resistor anyways?
Still learning about these cars.
Here are the ranges for each VATS resistor value:
402 ohms (386-438)
523 ohms (502-564)
681 ohms (650-728)
887 ohms (850-942)
1130 ohms (1085-1195)
1470 ohms (1411-1549)
1870 ohms (1795-1965)
2370 ohms (2275-2485)
3010 ohms (2890-3150)
3740 ohms (3590-3910)
4750 ohms (4560-4960)
6040 ohms (5798-6302)
7500 ohms (7200-7820)
9530 ohms (9149-9931)
11800 ohms (11328-12292)
We all are, my friend. There isn't a soul out there who knows it all...
Be well,
SJW
